Some TLC for my QV | Page 17 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,498
    Switzerland
    Urs STEMMLER
  2. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Cluster corner (those that were broken) reinforcements:
    Detail of glove box solenoid and map reading light/switch
    USB / 12V side
    NB: Cable passage in clock/odo/milage counter - avoids pinching them when the cluster is fitted correctly
    Fitting of the Power Steering speed sensor signal wiring (additional black loom)
  3. afterburner
    3,498
    Switzerland
    Urs STEMMLER
  4. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    Really like the new of cockpit instead of the plastic box! Neat job :cool:
    What are these? new back plates?
  5. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    #406 afterburner, Oct 24, 2021
    Image Unavailable, Please Login I added the missing numbers on the auxiliary instruments and the green arc in which operation is normal, for both the metrical and imperial system - just in case anyone wondered what the other bars mean. Including orange arcs:
  6. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    theunissenguido and MvT like this.
  7. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
  8. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    I was curious, not sure I read over it, and I am almost sure you did this, but did you check the valve measurements, cam shafts outs etc?
    There seems to be a an oil lubrication in the head on the side of the rotors. The first lubrication from the rotor side is drilled in an angle instead of strait down. Did you do this mod as well?
    I just recently came to know this from a F friend who brought his F in for a full service at the F dealer. They corrected this mistake. All engine (heads) have this and was after a long time corrected in the 348.
  9. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    No I haven't checked that - the heads were off 10 years ago and it ran fine since.
    I did drill the oil drain for the second gear hydraulic lock issue and that does solve the problem.
  10. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    No, I indicated the missing numbers and added the red zones (not good), green zones (good), amber zones (watch out) and in blue/green the lines for the oil pressure limits. Just for reference in case you were wondering what those lines mean on the instruments in relationship to the limits.
    ronfrohock likes this.
  11. jjmalez
    jjmalez F1 Veteran
    6,781
    Northern Illinois
    Joseph
    Hello,
    I just came across this thread. So very nice.
    Love the Mondial Coupe.
    afterburner likes this.
  12. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Time for an update: The re-assembly continues with the tail and fog lamps:
    Fuel filler flap
    Filler recess drain:
    Sunroof and dome light wiring, both sides have a ground:
    Sunroof drains - forward starting points at the A-pillar top:
    Ends inside the cowl through a grommet:
    Lower exits
    bonnet gutter drains:
  13. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Rear wiring loom installation - front door jamb to the last tail lamp and sideways to the centre console underneath the rear seat - tough job
    along the sill and up the rear fire wall
    engine bay connectors
    out the rear fire wall
    inside the trunk
    There are sheet metal clamps everywhere to hold them up. I used el. shrink tube to protect the loom:
    Some repairs needed here
  14. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    With the wiring installed and connected in the trunk the repaired trim can be refitted. First to go in is the vertical heat shield towards the firewall, screwed at the bottom and pop riveted along the top:
    and in; note the preserved factory tapes Image Unavailable, Please Login
    the double layer horizontal heat protection from the exhaust goes in next
    Note trunk lock emergency access trap:
    first layer in:
    FRP intermediate layer
    FRP trunk floor with additional heat insulation gets riveted in place
  15. afterburner
    3,498
    Switzerland
    Urs STEMMLER
  16. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    New engine bonnet sound deadening/heat shielding added
    cowl drain and heater hoses added
    rear wiring loom installed on center tunnel
    NOS door gasket arrived shrunk and delaminated... needs to be re-replaced - bad surprise:
    RH side fits perfectly
    Mondial script installed
    Plates and blinker repeaters
  17. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    engine bonnet gasket and edge seal
    trunk and engine bonnet locks installed
    all threads retapped - there are many!
    Good ground connections are crucial - battery cut-off and main ground
    wiper arm assembly installed
    AC dryer
    HVAC intake cover
    note ss screws with rubber washers
    filler neck gasket refitted
  18. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    tire pressure sticker applied
    heater valve in position
    hand brake switch installed
    trunk solenoid
    engine bonnet solenoid
    warning light connection for engine bonnet
    mileage counter
    washer hoses put in
    front bonnet pull cables and lock installed
  19. afterburner
    3,498
    Switzerland
    Urs STEMMLER
  20. afterburner
    3,498
    Switzerland
    Urs STEMMLER
  21. ronfrohock
    ronfrohock F1 Rookie
    4,175
    MA
    Ron Frohock
  22. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Jeka, decampos and moysiuan like this.
  23. 2cam
    2cam Formula Junior
    Aug 28, 2014
    750
    Austin, Texas
    MikeS
    Absolutely incredible level of detail and amazing work! Thank you so much for documenting everything. It really is beneficial to see how the cars are put together.
    2cam
    afterburner and moysiuan like this.
  24. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    Must be the newest Mondial in the world :)
    Absolutely epic restoration , you really must be crazy about this car (like the rest of us of course :) ). And as a daily driver, it is worth the work!
    BTW: your car is miss August in our calendar :)
