Some TLC for my QV | Page 18 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,480
    Switzerland
    Urs STEMMLER
    Ah that's great news thanks!
  2. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    Big issue: the side impact beams in the US replacement doors are very approximately positioned... the lh door beam doesn't give enough clearance to the door lock actuator rods - opening/closing the door works (just) but the locking motion needs more space/play than the original "adjustment" provided:
    Obvious factory hack...
    The beam on the other side is about massively lower in the area, so the lock works
    An increased space was cut out:
    That provided the necessary space for the locking action to work
  3. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    With that mechanical issue solved, next is the installation of the door wiring; plug pin attribution drawings help a lot:
    Additional window power (12V via a fuse directly from the battery)
    Taping pins together helps getting them through the bellow and door jamb:
    Floor courtesy lights
    Window relays ground
  4. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    bonnet gutter drain bellows (self-reproduced)
    Rad foam
    restored wiper motor installation with new grommets:
    followed by cowl air trim and wiper arms
    side intake strakes
    Problem... too much paint thickness in the critical area - paint chipped, will need a retouch.
    Removing paint on strakes and body was necessary to allow proper fitting - we're talking tenth of a mil...
    Horns installed
  5. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    #430 afterburner, Nov 29, 2021
    Various restored plugs, grommets and new spare tire belt (with original hardware) refitted:
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Antenna cable routed - there is a tab in the trunk to hold it up:
    down the rear seat back
    across the rh rear pax footwell, together with the handbrake cable, below an alloy protection into the centre console
  6. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    I added the wiring for the 3rd stop lamp to the RH cantrail wiring (for rear courtesy light and heater rear window) - additional ground using existing bolt at the top of the A-post:
    Gas pedal installed
    torsion bar actuator for RHD cover fitted
    Pedal hinge cover refitted
    Gas pedal return spring added
    3-part bonnet foam seal glued on
  7. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,696
    Argent/Brasil
    Guido
    Waw, that solution F used for acceleration pedal on the right side....great pictures overal, thanks.
  8. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    ... ball joints on both sides of the torque rod, works very nicely actually.
  9. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    254
    Connecticut
    John Jeffries
    I remember this thread from when you did the interior but just found it again and have spent the past few days catching up. “Wow” is an understatement.
    Others have pointed out the excellence of your work so I’ll focus on how impressed I am by your specific ability to take the small, complex parts - like switches - to pieces and get them back together again. My experience says it’s tougher than you make it look.
    AND, it appears you’re doing much of this refurbishment is an apartment? You must have superb familial- and neighbor-relationship skills in addition to project management.
    I was sorry to see the paint chips when the strakes went on. Will you re-do/re-paint the sides of the car as a result?
    I’m two years into a fairly comprehensive renovation of an ‘87 Porsche 924S and while I thought I’d been going pretty deep into it, I have not pursued the same level of detail (nor, it must be noted, is my Porsche/Audi anywhere near as low-volume as your Mondial, with all its low-production, hand-made parts).
    These special machines are, as you say, like a family dog and yours was very much worth saving. Silver/Argento is exquisite, much better than red. I admire your ethic and skill-set and commend your results.
    John/Connecticut USA
    2cam likes this.
  10. jjeffries
    Sep 4, 2012
    254
    Connecticut
    John Jeffries
  11. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    John thanks for your message... and yes, the "small" (as in no 4-post lift required) work was done in my flat and therefore all has to be done "surgically" or else I'll get banned/reported or worse!
    Funny thing I live in a car-free town so everything other than the body/suspension/drivetrain was hand-carried here and back by public transport. So effectively, I am the only person here that had a car at home - admittedly not in one piece at the same time but still.
    As for the strakes incident (one of THOSE moments) the rear wings upper half had to get repainted. The local Ferrari painter did an excellent job; the body crease and the relatively sharp rear corner allow for a paint transition. Lesson learned.
    The work on your 924 is fascinating and I like your saving and bringing it back to life. Those early/simple ones look quite pure. The paintwork restoration is amazing and so it the dashboard main body rescue operation... Interesting to see how mass-produced looking Porsches are compared to our cars.
  12. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    Correct paint code sticker applied - was looking forward for that!
    Restored electric board brackets with inserts:
    Electric board fitted (Guido's has been working perfectly for the last 10 years)
    Next will be the restored main loom through the front bulkhead:
    Mileage counter and min/max pressure switch
    That took A WHILE to get through - the hole on the inside is at the different height from the one on the outside (I do know why)
    Main junctions between dash/console and engine loom on lh front A pillar
    Good care taken on all grounds:
    overall view left side
    right side, note ground and power supply to window accelerators (black wire with blue connector)
  13. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    Main instruments connections on bulkhead behind steering column (totally inaccessible once the panel is in - better not miss anything there)
    Auxiliary instruments stack connectors next to it
    Overall view rh side
    Gas pedal covers added, a solid medal floor mounted cover over the torque bar and a thermo formed plastic cover over the pedal base
    Retapping gearshift housing threads on chassis
    in absence of the mounting bolts cable ties hold the castings together:
    et voilà:
    gate and knob fitted (protects my eyes while doing dashboard gymnastics)
    Handbrake warning light cable passage behind rear seat foot well over the centre tunnel's structure
    centre tunnel's rear passenger air vent supply tube and wiring laid in
    2cam likes this.
  14. theunissenguido
    Jan 21, 2004
    2,696
    Argent/Brasil
    Guido
    Impressive ===== Urs, your fuse board is the 3th board produced and at that time, it was still in experimental fase. In the mean time a lot of progress in production en testing...(there are 215 boards spread over the whole world) so if you want a board thats new, similar with your car now, just let me know. Tumbs up !!
    UKtifosi likes this.
  15. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    Gearshift linkage fitted (fine-threaded bolt)
    rubber boot to seal engine bay from centre tunnel
    bulkhead view
    blinker relay relocated from upper bulkhead (inaccessible) to dashboard tie (easily accessible from below the dash)
    stop-light switch with deviation for 3rd stop lamp
    centre console main body fitted
    detail shots of various sections of console from front to rear
    2cam likes this.
  16. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    Guido thanks that's a nice offer - at the moment all is well and I won't touch anything that works :D but should I encounter issues I'll call your hotline ;)
    theunissenguido likes this.
  17. UKtifosi
    UKtifosi Karting
    May 7, 2014
    112
    Kent, UK
    Paul Glyde
    Guido's board transformed my 83 QV. Highly recommended.
  18. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    Centre console connectors inside the dashboard on the passenger side
    HVAC/interior lights timer/check control ecu panel installed
    relocated blinker relay - so it's easily accessible - installed on rh lower ip tie strap, and connected directly to the battery to improve blinker brightness and speed. Brown wire will have a direct battery feed. Image Unavailable, Please Login
    Meanwhile, preparation of the rear speaker panels - period NOS 2-way speakers, custom pattern inspired by the front speaker pattern. Speakers were rotten so I replaced the foam:
    cleaned
    re-glued new foams
    installed into the original holes, with water protection caps on the top half:
    JLF likes this.
  19. afterburner
    3,480
    Switzerland
    Urs STEMMLER
  20. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    fibre optics lines fitting - the green bunch
    radio ground strap
    rear speaker cables - new ones, the original wires were broken
    12V and ground supply for the future electric power steering
    rh side dash ground, with additional EPS ground and spare 12V feed for potential future additions.
    Also passing behind is the red 3rd stop lamp wire:
    remote and separately powered blinker relay wiring going into the original plug:
    overall situation rh dash side behind the cluster Image Unavailable, Please Login
    additional 12 supply for the future
  21. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    new wiring passage behind steering column and out to the front trunk
    front trunk wires passing behind the HVAC out to the front trunk (brakes etc
    completed pax side dash wiring with additional 12V power wire for the window accelerators (thick black one) Image Unavailable, Please Login
    All new wires fed via a separate fuse box on the driver's side wing, powered by the battery
    front trunk ground
  22. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    The rear quarter windows originally had hand-painted black-outs in the rear vertical section and along the lower edge to hide the view behind the interior trim from the outside. This had partially come off over time so I repainted it:
    rear done, clearly visible lower edge degradation:
    rear window lower trim goes in first
    then the C-pillar trim and seatbelts can be fitted
    next reel covers and the lower quarter window trim
    you can see why the additional black-out is necessary
  23. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    B-pillar trim fitted with the seat belt bolts
    next lower rear quarter trims
    center console arm rest and glove box
    A-pillar trims
    sunroof opening internal gasket
    rear wiring passage through firewall with "squeeze" protection for the hvac vacuum line
  24. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    Upper rear quarter panels fitted
    finishing the quarter trim with the speaker panels
    front firewall main wiring passage with wiring protection foam added
    exterior rear window trim tabs needed paint removal and local repainting:
  25. afterburner
    3,480
    Switzerland
    Urs STEMMLER
    trim clips positioned on the front door
    door window trims fitted
    sealant applied to mirror base
    mirrors fitted
    rear body trim is quite complex with a combination of vertical clips on the window area and sliding pads in the pillar zone that need to be tightened from the engine bay side once the trim is on place:
