Some TLC for my QV | Page 19 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
    rear triangular trims fitted - interesting how much too small the rh side is originally. Gap covered from behind by a spare strip of vinyl:
    Zones behind the rear seat attachment, seat brackets and nuts sprayed black to hide gaps and prevent light from being reflected:
  2. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  3. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    restored front end wiring loom
    ground points restored to perfect connection:
    ground points behind the front bumper side sections - very important, one is for the electric board:
    the yellow P clips are on the sides
    more grounds on the rh side
    electric board side connectors - the vertical ones on the left
    horn compressor
  4. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Final fitment of front bumper and side panels, note blackout at the top of the bumper to visually reduce the gap size.
    light connections:
    the side panel spacers needed restoration
    cleaned up
    anti-corrosion protection for the inside of the side sections
  5. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    theunissenguido likes this.
  6. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Window motors next Image Unavailable, Please Login Image Unavailable, Please Login
    ... layout, for the record
    that one motor wire didn't look ok so I replaced it:
    trouble is - the cable is too short for the replacement door - I have no idea why but...
    Measuring the difference with a string taped on:
    new 1.8mm wire ordered and correct length fitted. Not fun.
    special tool #17-B6
  7. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  8. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Next in are the central door locking units, rh (driver's) needed a new microswitch and condenser previously hence the cutting marks and alloy tape to seal it. Note the spacer I glued on for easier fitting; it aligns the push pull direction with the lock correctly:
    pax side (black unit) - mounting hole missing
    Nylon wedges of later cars for rollers pressing the window tightly fitted to screens - roller will be added later should the window vibrate
    door lock actuators rods/cables fitted
  9. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Aerial motor: NOS from Italy, needed a custom made wedge-washer to get the angle right so the nut tightens it down without bending it and it clears the open trunk. Empty area with antenna cable and wiring:
    housing drain trough the wheel arch
    wheel arch side
    wedge washer
    installed - note the "dent" to the trunk gutter acting as a drain from the big hole in the black finisher so water wouldn't accumulate:
    trunk side
    and trimmed in the original wrap:
    Jeka likes this.
  10. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,769
    Argent/Brasil
    Guido
    Urs, how fast/slow is window speed after all that work ? I changed my QV doors to 3.2 doors with the other mecanisme. A big difference...
  11. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Generally the windows are up before I reach the office.
    Ademir 70 and ronfrohock like this.
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    that:
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    4 secs down, 5 secs up. That's acceptable. Original motor but new grease and direct power. My switches control a relay that feeds the motors, and the ground is in the door.
  14. moysiuan
    moysiuan F1 Rookie
    4,300
    Canada
    Where did you get the stickers for the wheels?
  15. theunissenguido
    Jan 21, 2004
    2,769
    Argent/Brasil
    Guido
    Waw, first time I see those working like it should on a mondial. Congratulations !
    afterburner and moysiuan like this.
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Superformance, but NLA. I could make them but not sure how many people would be interested.
    ronfrohock likes this.
  17. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    254
    Connecticut
    John Jeffries
    Exquisite workmanship, an inspiration.
    And done in an apartment and parking a garage.
  18. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Thank you John!
  19. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Time to fit the rear trim of the trunk, now that the side panels are in. Again, they needed to be trimmed by as much as an inch to actually fit before redrilling the mounting holes:
    rh side first, it fits below the lh side:
    lh side
    lock cover secures the centre top in place
    Secondary window frame gaskets fitted:
    the rear wiring loom passing from the main lh sill across the rear passenger footwell is protected by an alloy channel pop-riveted into the floor:
    tight fit, ends needed to bend up a bit to protect the cables:
    front seats put in - one more big thing out of the way!
    AC low-pressure line fitted - necessary step to fit the HVAC as it will pass between the firewall and the unit on the RHD version:
  20. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    New correct size lh door gasket arrived and fits:
    door panel elements refitted:
    accelerator cable fitted, incl. a pedal-return spring:
    the center wiring loom holder on the lh sill had broken off and I hadn't noticed it while the car was stripped:
    An alloy strip and a pop-rivet solved that one
    With the plastic sleeve protection on:
  21. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Last view of HVAC unit zone before fitting it:
    Unit in positioned before fitting it - note the return hose passing in front of it. It's 2-man job to hold, move and make sure you don't squeeze, pinch or break anything until it's on the correct position:
    Done - medium fun-level Image Unavailable, Please Login Image Unavailable, Please Login
    Huge psychological step though.
  22. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    low pressure hose passage in front of/above the steering column Image Unavailable, Please Login
    from the front trunk with pedal box removed Image Unavailable, Please Login
    passage below the HVAC unit
    rear passenger vent hose (silver) and evaporator drain (black)
    copper connector for future heater hose from the engine
    pax footwell ecu panel connected Image Unavailable, Please Login
    Note main power line bypass of the original connector. Amazing how well things work when they get 12V...
    3 HVAC relays refitted below unit/above centre tunnel - labels help trouble shoot:
    center tunnel front section fixed part fitted
    pax side has a removable panel with velcro fitted carpet to access the radio wiring:
  23. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Next up is the connection of the centre console panels - wiring, fibre optics and vaccum - connection of the vacuum hose from the engine to the manifold plug intake: Image Unavailable, Please Login
    little spider got attracted?
    connected to the push-button unit:
    electrics and lights connected to the centre panel
    Done
    radio fitted
    EQ fitted
    and everything connected - spaghetti al pomodoro
  24. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Front passenger footrest - that panel was NEVER fixed in the car - I know why now - too small! When fitted to the left side chassis bracket, the right side couldn't reach the mounting hole, neither sideways nor in depth by a big margin (25mm both ways) - besides the left side's hole being misplaced... I knew it was loose but could never figure out why. Now I know:
    so when fitted to the left side - which I can't change because it's the wheelarch:
    The right side if way off its intended thread:
    But the hole angle was actually correct - so a sideways extension + a spacer would fix the issue:
    Here we go:
    painted and trimmed - what a difference when you sit in the passenger seat and it doesn't feel like stepping into cow-poo - rock solid now:
    trimmed spacer is invisible:
    Great "improvement" - this was a factory defect.
  25. jjeffries
    Sep 4, 2012
    254
    Connecticut
    John Jeffries
    Every stereo should have an equalizer. Great invention.
