Some TLC for my QV | Page 27 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
  2. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
  3. moysiuan
    moysiuan F1 Rookie
    4,295
    Canada
    Unless these suppliers can confirm the manufacturer, I presume they are all pattern parts made by the same supplier, most likely made in China. If they are indeed the same, this is not a very good price.
    afterburner likes this.
  4. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    I think it shouldn't be, then it would be 115518A (A as in Alternative) instead of 115518, but I see they are not in stock.. that is why they say the alternative is available. so if you order you would get the alternative and pay the OEM price :(.
    I bought these (I call it candy) parts at my local dealer for at the time small money not even 100 euro/$ for a set. I consider myself lucky now that I got a spare lying around! I'm not sure where they get these parts from nowadays, but at least you have warranty for a long time.
  5. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    85QVEuro and theunissenguido like this.
  6. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Car went for a regular 10'000km service with fluid and filter changes and some other items that needed attention.
    I got 4 new engine mounts and a new tank cross feed. With the new mounts and the gear linkage adjusted, there is the correct clearance and shifting is smooth again.
    Photo take before the tank cross feed was replaced:
    Also saw more deterioration on the tank vent pipes so they were replaced as well
    And 3 of the 4 front suspension bushing welds had cracked with the corresponding noises so they were rewelded.
    The the loss of power during acceleration re-appeared right after the service. Again, it was due to a dirty inline filter at the fuel distributor. I don't know if that's a gas station problem or something deteriorating upstream? Fuel accumulator maybe? Everything is tight though and holding pressure as it should. I changed it and the engine runs perfectly again.
    The old one:
    I'll clean it up and keep as a get-home spare.
    85QVEuro likes this.
  7. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    I also replaced the driver side door handle. It had visually deteriorated from use and the key turning movements that should have a positive stop at around 45° to the left and right became somewhat vague.
    I found a good quality second-hand item at Eurospares and fitted it today. Getting the locking/unlocking linkages in concert with the central door locking sensor is always fun - but it all works as it should now. And it looks neat again ( the surround seat will settle in a bit with use).
  8. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    The fuel filler solenoid stopped working with the flap closed a while ago - it would fire with the flap open though... Italian humor?
    The other day when I released the flap manually, the solenoid came apart. Put back together and refitted, it works perfectly now.
    Thanks to the hole drilled in the plunger, it's super easy to refit.
  9. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,768
    Argent/Brasil
    Guido
    Was'nt that your kid playing with that flap some time ago ?....HK humor ! :D
  10. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Good memory Guido!:cool:
  11. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    While my car was parked out in an industrial area of HK it got a light coat of black overspray from a
    nearby garage applying chassis paint... I didn't notice until I drove off that night. It was misty and required a few sweeps with the wipers to clear the windshield. I thought. A loud whoosh whoosh resulted in a fairly bright white windshield from the oncoming traffic. Almost no visibility. Very scary. I pulled over and carefully used a new cutter blade to clean off the paint from the windshield. Millions of tiny hard dots:
    Joe from the board here kindly advised me through the process of claying the car, which was a new process for me. Thank you.
    A lot of work but successful:
    The clay bar even got rid of the nasty brownish coat of brake dust on the centre caps!
    Since I was cleaning... I had a closer look at those exhaust tips. I always thought the chrome had come off:
    But - no, it was hardened whatever comes out the tailpipes:
    Success:
    Cleaned up back end looks good again
    Then those things inside broke loose shortly afterward and rattle very very annoyingly...
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    The engine started to ping (?) under load and since I had leaned the engine (warm control pressure only) I was wondering if it was missing a bit of fuel - there was no direct time correlation between my WUR work and the sound starting. Or is it that exhaust muffler with loose parts inside?
    Fuel filter check was the first thing I did and I did find more muck in the inline FD fuel filter - I wonder if something is going somewhere upstream? Or dirty fuel?
    It had no effect on the pinging under load.
  14. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    While conducting some test on the engine I did find 2 things, one of which could have an influence on WOT performance:
    - The manifold pressure line to the WUR had a leak - fixing it had no influence on the pinging.
    - The AAV didn't close when hot
    So, too much air for sure, and impossible to adjust idle correctly, which is a problem I had for a while (cold too high, warm too low). I tested the electrical circuit and it works as it should. I also checked the AAV and it does move between it being in the freezer and then connecting to 12V. Obviously an adjustment issue. I adjusted it to be closed when the engine is hot and voilà, idle adjust perfectly now between 1250 cold and a steady 1000 when warmed up. It did not change anything on the pinging but it's nice to have good idle.
  15. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Back to the WUR then. When I got it back reconditioned by the specialist, the control pressures were:
    system: 5.35 bar > ok
    cold (20°C) with vacuum: 2.5 bar > should be 2.2 max, so too lean
    warm with vacuum: 3.5 bar > OK but on the rich end
    warm w/o vacuum: 3.05 bar > OK but on the lean side (WOT)
    The average fuel consumption was 14.5L/100km, way too high.
    My conclusion was: It should be richer when cold and leaner when hot, and richer under WOT
    Since cold starts where not a problem here as it's rarely below 10°C I concentrated on the warm control
    pressure to lower the high fuel consumption
    system: 5.4 bar > ok
    cold (31°C) with vacuum: 2.6 bar > OK, but on the lean end
    warm with vacuum: 3.9 bar > OK, on the lean end
    warm w/o vacuum: 3.2 bar > too lean, 3.1 max (WOT)
    The average fuel consumption is 13.1L/100km now.
    The engine ran nicely, and only just recently the pinging under load developed. I decided to look into the WUR again and see if I can get both the cold control and WOT pressures richer while keeping the warm pressure high to keep the fuel economy.
    cold (23°C) with vacuum: 2.2 bar > OK, in the middle of the range
    warm with vacuum: 3.7 bar > OK, on the lean side of the range
    warm w/o vacuum: 2.8 bar > OK, on the rich side of the range (WOT)
    The engine pulls runs really nicely, starts hot and cold, and - no change to the pinging under load.
    Back to the rattles in the muffler?
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Here some information re the WUR pressure adjustments:
    - warm control pressure is determined by the height of the fuel cell in the body
    - cold control pressure is determined by the depth of the bimetal spring post in the body
    - WOT control pressure is determined by the screw position on the underside, hidden behind a metal cap.
    To access that screw, you need to drill a hole in the bottom cap (on this particular WUR, the bottom side of the vacuum diaphragm is essentially at barometric pressure). I will reseal this hole later. Adjustment is via an Allen key.
    To set it up from scratch it's important that:
    1) the fuel cell is far enough out of the body so when you refit to bottom assembly, there is no spring pressure on it at all (the push bar needs to be loose). In my case the fuel cell stood about 5mm proud.
    2) the bimetal spring post must be enough out of the body so that it will not push down on the spring perch when the bottom assembly is fitted. In my case the post stuck out about 3mm.
    3) the WOT screw is in until the small spring sits flush with the big spring, basically neutralising it's effect (so the pressure can be lowered from the basic warm control pressure setting)
    I wrote up the procedure to both just measure or do the setup from scratch:
    ellum, Brooklands and theunissenguido like this.
  17. schelle_pelle
    schelle_pelle Karting
    Oct 22, 2021
    209
    Berlin, Germany
    Hi Urs,
    thanks so much! I was about to ask if you could give some more details on how to adjust both WUR and AAV. Especially the pressures of the WUR and the needed equipment.
    Thanks!
  18. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Michel you're welcome. You'll need a pressure gauge with tap, vacuum pump, infrared temp gun, a steel rod not bigger in diameter than the bimetal strip post, and a big hammer...
    The AAV get adjusted by loosening the small nut and moving it radially toward or away from the centre of the AAV.
  19. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  20. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  21. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  22. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    This is how I understand the working principle of the WUR.
    Please educate me if you see any errors. Thank you.
  23. schelle_pelle
    Oct 22, 2021
    209
    Berlin, Germany
    Wow! Impressive! Thanks so much!
  24. theunissenguido
    Jan 21, 2004
    2,768
    Argent/Brasil
    Guido
    Can the Pingping be related to bad fuel...mixtire of 95 with 98 on the pump ? Selling it as 98 octan.
