Some TLC for my QV | Page 29 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
    Mr Schulz good observation - but in this case (older engine generation) the belts are different from the ones used on the t engine and are fitted correctly. These older Gates high speed belts have a different design and are made from different materials than the (much cheaper) normal V-belts. They are not interchangeable with anything else due to their different sections and angles.
    ronfrohock, cavlino and Mondi Cab like this.
  2. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Knob painted, looks "original"
    The hex fit needed a little clean-up work with a needle file to make it fit:
    Looks good and works. I will add 1/10mm to the hex size to compensate for some shrinkage of the 3D print resin; ABS in this case. That should make it fit fine without rework.
  3. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Here's the STP file in case someone would like to mill or print the knob:
    moysiuan and ronfrohock like this.
  4. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    85QVEuro and moysiuan like this.
  5. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    581
    NYC
    Joe
  6. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    :D no leaks in mine!
  7. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  8. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Back to the "sticky" gas pedal: The control curve of the pedal position laver had a slight wear-related dent, which I filed out to regain a smooth curve (dented zone after rework):
    The roller on the throttle plate actuator was badly worn, and had play radially and axially:
    The new roller on the original axis, incl. a washer/screw holding things together:
    Counter nut on the backside
    Back in the car
    It works perfectly now.
    So for those of you with a sticky pedal - after checking the free movement of the pedal and cable:
    Check for uneven were in the control curve and a "playful" roller.
    85QVEuro and Oleino like this.
  9. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  10. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    MvT and theunissenguido like this.
  11. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Then the misfiring started again... occasionally, when cold, but runs on all 8 when warm? Long checking story shortened: HT leads to 5-8 carbonised, literally.
    The clips holding them in place failed and the cables were probably getting too close to the front header.
    New set was ordered on Tuesday lunchtime here and arrived on Thu lunchtime. Thank you, Superformance.
    I installed the leads further away from the heat source this time - less tidy looking but possibly life-extending?
    And yes, ran nice again! Here are the values of things when new, in case someone is interested:
    1.6kOhm/foot for the HT leads, and lead lengths in case someone wants to build his own.
    Brooklands, gunn and 85QVEuro like this.
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    A week later - misfiring again!?! Started on Friday night on the way back and got worse but I made it home. tach was running so I didn't suspect bank 5-8/rpm/tdc sensor of that bank. Next morning - clearly only running on 4. Strobe lamp confirmed bank 1-4 had no spark. I ran 5-8 on coil 1-4 and it ran. So coils were good. Checked the 1-4 TDC sensor at the diagnostics plug and it checked out. Here the new value for reference:
    Next under the car to check the ecu connection:
    No tdc signal... wiring issue then between the sensor and the ecu. There is one round plug in that line that had a repair on bank 1-4 (by a previous owner) so I suspected and issue there.
    I undid that part of wiring and ... that repair was not the issue! So must be the plug at the sensor, where there are 2 lines departing (one to the diagnostics plug, which checked out, and one the the ECU connector, which didn't show continuity). Sure it was there:
    This is not perfectly accessible, the insulation is rock hard and the copper obviously brittle... and to make things more interesting - koax wiring.
    And it was Sat evening by now. On Sunday morning, I was scheduled for a charity drive for the underprivileged kids, taking the old car ferry around the harbor. I needed the car running.
    I tried the hacking into the loom trick - which just showed how fragile the wires are. The rest broke off too:
    All in a garage 35+°C hot and no air flow... I made a bridging cable with small crimp plugs carefully opened up to suit the Marelli/AMP interface and 2 bullet connectors for connecting to the 2x2 original wires:
    Installation was successful
    And sweet she runs again. Then I had to clean her. Long day.
    85QVEuro likes this.
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    The left hand fog light (used as a daylight flasher) didn't really light up anymore - just very dim. Grounding issue? Na, dying bulb.
    H2 100W are not available here but I had a spare one left, made by Hella in South Korea, and of the wrong interface dimensions!!!
    Careful use of needle files permitted fitting... but seriously Hella? And they are NOT cheap.
    theunissenguido likes this.
  14. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    So, that rattle over bad roads on the front right that stops when on the brakes is:
    Any good ideas how to prevent this?
    Brakes work normally, and got plenty of pad thickness left.
  15. gunn
    gunn Formula Junior
    Aug 30, 2021
    326
    Gunn S
    It's hard to see in the video but I believe that the pad is rattling between the piston and the rotor.
    Since there is no clip that I recall holding the pad in with tension OR a clip on the back of the pad that goes into the piston itself (the brakes from a mustang cobra had these), I've used some blue goo on the pad backing to help keep in in laxe and minimize these kinds of rattles.
    IIRC, it was a copper or some other high temp infused goo. You want the goo or paste. You don't want the sprays (they never work)
    Examples
    CRC disk brake quiet
    Brembo b quiet
  16. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,767
    Argent/Brasil
    Guido
    Urs, your car has past the 160.000 miles. Is'nt this the moment to change the calipers for new ones ?! You have changed almost everything on this car, so new calipers would be a good solution. :D
    afterburner likes this.
  17. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Correct, and only the inner one. The outer pad is sort of secured by a leaf spring.
    Correct, it just sits there.
    It seems the distance is quite far (I haven't measured) for any of these products to work.
    Reading the descriptions, it looks like they prevent noise when the brakes are applied.
    Mine work perfectly, they just rattle when not in use...
    Possibly the caliper isn't floating easily enough/needs to be re-centered on the rotor?
  18. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Guido I had the calipers rebuilt at the time of the restoration, at 132'000. They've only done 28'000 mls in 3.5 years. So they should be alright...
  19. gunn
    gunn Formula Junior
    Aug 30, 2021
    326
    Gunn S
    Even with pressure not applied, this goo is sticky enough to hold the backs of the pads onto the bracket or piston face.
    Your idea about noise on the guide pinswould make sense if the pistons were floating and rode on guide rods built-in to a retaining bracket. The sn95 mustang GT used a setup like this. The solution is to replace the guide pins or lube them up with a high temp grease.
    However, from what I recall the mondial piston is hard bolted to the spindle with the bracket pre integrated. In this case, putting something to absorb the vibrations. New pads would take the slack as well.
  20. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    That's what I understand is the case on those brakes - there is one piston pushing against the inner pad, and the cylinder housing reaches the the outside and presses that pad onto the rotor.
  21. theunissenguido
    Jan 21, 2004
    2,767
    Argent/Brasil
    Guido
    Can you check if the brake discs are thick enough ? To small can also be the raison for pads to float.
  22. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    They should be.. same age as the calipers, pads, hoses, master, etc.!
  23. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    I'll have to change tires soon - wear is symmetrical on both front tires but I'll have to check camber and toe. Car drives straight and pulls straight under hard braking but the wear pattern on the inside isn't what I like to see.
    Maybe I'll have to take those roundabouts slower?
