Some TLC for my QV | Page 32 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
    Not a 100% but I am pretty sure they were - I had no solvent that would remove the original paint so I sanded things flat before repainting. I am sure it'll last for a while though.
  2. schelle_pelle
    schelle_pelle Karting
    Oct 22, 2021
    209
    Berlin, Germany
    Interesting... Was powder coating a thing in thr early 80s?
  3. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    It's been around since the 50s.
  4. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    581
    NYC
    Joe
  5. 85QVEuro
    Jan 15, 2021
    581
    NYC
    Joe
  6. 85QVEuro
    Jan 15, 2021
    581
    NYC
    Joe
  7. 85QVEuro
    Jan 15, 2021
    581
    NYC
    Joe
    thanks to Urs for providing the inspiration for doing projects like the ashtray +++++
    greatscott73 and afterburner like this.
  8. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Another small touch-up project - airbox cover had suffered some fuel spillage a while ago:
    Luckily the printing wasn't affected, but I did touch up the missing white paint on the ufi
    Those paints and brushes are really nice
    Result
    Image Unavailable, Please Login Paint prep, sanding and masking
    Paint - I can't get any crackle finish here Image Unavailable, Please Login
    Cleaned up, the paint line will eventually blend in better when it's all dried up and washed a few times
    djs308, Brooklands and Alden like this.
  9. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Re the clutch cylinder repeatedly failing: Heat might be the issue looking at the melted boot. I designed a heat shield based on the workshop manual's drawings and some photos I took:
    And fabricated it from an old sheet of alloy to test fit: Image Unavailable, Please Login
    It fitted alright
    That's in the car at the moment. I then made a proper one with a head protection insert
    Done, will be fitted the next time the car's up in the air:
    Side observation - in Switzerland you can still get 100 Octane gas, which doesn't contain Ethanol apparently
    85QVEuro, theunissenguido and Alden like this.
  10. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  11. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Alden, 85QVEuro and moysiuan like this.
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  13. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,768
    Argent/Brasil
    Guido
    Good ideas ! Thanks Urs....
    afterburner likes this.
  14. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    So - speedo keeps dropping to zero intermittently above 40mph so I pulled it to check the move the pot and add a tiny drop of WD40. No change, so crawled under car and saw this on the sensor plug:
    Off it came and I drilled a hole through the red side of the plug so solder in a new wire. On the green side I was able to reuse the cores so added a new wire:
    Prepped for refitting:
    Refitted
    ... and the problem is still present, with a very recent speedo sensor?
    So I refitted my original repaired sensor (see above):
    ... and the speedo works normally! The new sensor already failed... not good.
    Alden likes this.
  15. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    RHD only issue with the driver's footwell carpet due to the stepped floor (gas pedal torsion bar) - the carpet wears off really quickly due to the clutch pedal heel. So I had the carpet shortened to before the step:
    Cardboard template for a hard cover with a angled end surface:
    Ally part made and trimmed with a 2mm rubber mat, fitted with velcro so it can be removed to access the panel screws.
    Fitted, solid and cleans up the area permanently
    Also, the cassette compartment screws were always loosening themselves so I drilled bigger holes for larger diameter screws:
    Alden likes this.
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Alden likes this.
  17. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Engine started missing again, as soon as she warmed up. Fuel filter checks revealed nothing:
    Caps and rotors are perfect, all HT leads have continuity to extenders
    But some, not all, extenders have burn marks:
    Image Unavailable, Please Login including on the spark plug connector
    They check out in terms of resistance though. I changed them:
    No change... The sensors all test out OK in terms of their internal resistance, both at the diagnostics plug and all the way down to the ECUs' plugs. I also tested all the wires up to the coils without finding any discontinuity. The coils' internal resistances are as follows (for reference):
    Coil 1-4 low voltage 0.6 Ohm
    high voltage 4.68 kOhm
    Coil 5.8 low voltage 0.7 Ohm
    high voltage 4.72 kOhm
    Nothing obviously wrong other than a failed ECU? Before considering that I pulled the 3 sensors and they were very contaminated with clutch dust:
    Could this be the reason for their failure at higher temps?
    Alden likes this.
  18. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Nothing visibly or measurably wrong with old vs new sensor. But they need modifications to the holes spacing as you can see in the below pic:
    very magnetic...!
    3 new sensors that actually fit
    and refitted - all three plugs at the car's side are broken by age. I secured them with cable ties until I can source a new loom or make one with new plugs:
    Re the burn marks on the extenders both sides: I also noticed that the HT lead caps on the cam covers would not all sit at the same height and some of them wanted to be lower down = they'd pop up a few mm after fitting. Possibly the reason for the bad connections between the connectors and the plugs?
    Alden likes this.
  19. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Alden, theunissenguido and 85QVEuro like this.
  20. theunissenguido
    Jan 21, 2004
    2,768
    Argent/Brasil
    Guido
    Conclusion = new is not always better !
    afterburner and ronfrohock like this.
  21. Alden
    Alden F1 Rookie
    3,777
    Central Florida
    Yes, they can pop off! A few years ago I decided to check and clean my spark plugs and when I put everything back together after about an hour of driving, three or four leads popped off and my car wouldn't run! When I had my major service done a year ago, they also found that I had a misfire and one extender that was burnt all the way through!
    Alden
  22. theunissenguido
    Jan 21, 2004
    2,768
    Argent/Brasil
    Guido
    Alden likes this.
  23. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Would you sell them?:D
    Alden likes this.
  24. theunissenguido
    Jan 21, 2004
    2,768
    Argent/Brasil
    Guido
    Alden likes this.
  25. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Very nice Guido!
