Some TLC for my QV | Page 33 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. schelle_pelle
    schelle_pelle Karting
    Oct 22, 2021
    209
    Berlin, Germany
    I overhauled mine and reused all the original plugs and redid just the cables and connectors with high quality ones.
    The thread with pictures and links must be around somewhere here.
    Alden and afterburner like this.
  2. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
    Happy New Year to all!
    The Mondial did 5'935 mls in 2024, despite me being overseas for about 6 months.
    When I measured the sunroof tube for Michel and had the trim panel off I finally repositioned the access hole for the emergency handle, which was off by too much to be useful:
    New position estimated
    Jigsaw
    Araldite
    Retrim with the saved material
    It blends in alright
    And the hole is where it needs to be
    Just in case...
    85QVEuro and Alden like this.
  3. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    schelle_pelle, ronfrohock and Alden like this.
  4. Paulmendit
    Paulmendit Rookie
    Feb 26, 2024
    42
    Paul Coles
    I wonder if there has been a bad batch of these. I replaced the faulty sensor on my QV in the summer and it failed completely after 15 miles. Eurospares were very good though and sent out a replacement.
  5. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Paul that sounds just like it...
  6. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  7. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  8. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Testing a custom-made car cover. It "fits" but not well or as intended.
    Not sure if we can work with this supplier as they don't follow the supplied patters.
  9. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    The journey commences:
    Getting out of the driver's door was tight:
    The front wheels get strapped down while the rear wheels get blocked in position with a wooden frame nailed into the container's floor boards, then strapped down as well. Ships bank!
    Truck to HK port:
    The (very trustworthy-looking) barge to transfer the container from the local port to the deep sea port of Yantian on the east side of HK, on the mainland:
    From there, it is currently travelling to Antwerp (B) on the Trocadero:
    Bon voyage!
    AUDIO RESEARCH, 85QVEuro and Alden like this.
  10. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    581
    NYC
    Joe
    Fascinating to see - Best of luck with the rest of the voyage - look forward to see driving shots in Switzerland!
    afterburner likes this.
  11. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,769
    Argent/Brasil
    Guido
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  14. theunissenguido
    Jan 21, 2004
    2,769
    Argent/Brasil
    Guido
  15. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    I am doing the t wiring diagram that was included in that pdf, but there is no reference to which car it belongs - which is useful information. It includes side markers on the index pages so I suppose it's for the US version. I'll understand more once I have all sheets marked.
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  17. theunissenguido
    Jan 21, 2004
    2,769
    Argent/Brasil
    Guido
    Almost home ! Are you going to drive your car to Schweiz or in/on a trailer ?
    The wiring diagram in that Pdf is for all models I believe. US, Eu, CH,J, SA...
  18. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Guido no I can't do that. The container incl. the car must be imported officially and at the same time so it's considered moving household belongings=tax free, and the car given the corresponding papers for registration.
    I will analyse the t diagrams when I have them named (not codes for items) and complete to see if they cover all versions.
    There would have to be multiple diagrams for the same system and I'll only see that once they're done.
    theunissenguido likes this.
  19. Tsionic
    Tsionic Rookie
    41
    Chicago, IL
    Freddie Freeloader
    So do you have to remove the entire dash to get at the shell of the glove box? Trying to replace my faulty Hella socket
  20. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    I guess you can loosen the side of the dash and pull it forward enough to access the nut of the socket.
    Tsionic likes this.
  21. Tsionic
    Tsionic Rookie
    41
    Chicago, IL
    Freddie Freeloader
    Yes sir, I will try that later today. Thanks!
  22. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Updated wiring diagram list:
    GT4
    208gt4_wd_eu_102-75
    308gt4_wd_eu_91-74
    308gt4_wd_us_100-74(75)
    308gt4_wd_eu_124-76_single_distr
    308gt4_wd_eu_124-76_double_distr
    308gt4_wd_aus_135-76_till12954
    308gt4_wd_aus_135-76_from12954
    308gt4_wd_us_126-76
    308gt4_wd_us_144-77
    308gt4_wd_us_163-78_single_distr
    308gt4_wd_us_163-78_double_distr
    GTB GTS
    208gtbgts_wd_eu_188-80_contact_breaker
    208gtbgts_wd_eu_188-80_el_ign
    308gtb_wd_eu_116-75
    308gtb_wd_aus_134-76
    308gtb_wd_us_144-77
    308gtb_gts_wd_us_150-78
    GTBi GTSi
    308gtbi_gtsi_wd_us_186-80
    308gtbi_gtsi_wd_eu_flashers_195-80
    308gtbi_gtsi_wd_eu_fog_195-80
    308gtbi_gtsi_wd_eu_rr_fog_only_195-80
    308gtbi_gtsi_wd_us_212-81
    308gtbi-gtsi_wd_us_216-81(82)
    MONDIAL
    mondialqv_cab_wd_eu_251-82
    mondialqv_cab_wd_us_289-83
    mondialqv_cab_wd_us_317-84
    mondial32_cab_wd_eu_ch_488-87
    mondial_t_cab_wd_eu
    mondial_t_cab_wd_us
    85QVEuro likes this.
  23. 85QVEuro
    Jan 15, 2021
    581
    NYC
    Joe
    FChat people - if you have a model that Afterburner lists above, get his wiring diagrams as they are invaluable in understanding your car's wiring and more importantly, fixing you car's wiring and electrical gremlins (and who doesn't have some electrical gremlins?)
  24. gunn
    gunn Formula Junior
    Aug 30, 2021
    326
    Gunn S
    I would never have been able to rewire my 12V system without Afterburner's diagrams.
    Totally worth it to replace my fuse panel with a more modern one.
    ronfrohock, afterburner and Alden like this.
  25. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Thank you Joe and Gunn!
    ronfrohock likes this.
