Some TLC for my QV | Page 9 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
  2. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    theunissenguido likes this.
  3. JLF
    JLF Formula 3
    Sep 8, 2009
    1,711
    Great job.
    afterburner likes this.
  4. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Interior Door Handles before and after
    missing rubber support on one side - originally missing?
    disassembly and clean-up driver side
    reassembly - with the missing rubber gasket nla I addes rubber spacers in the mounting area to re-create the correct assembly height:
    disassembly and clean-up pax side
    reassembled:
    done, including repainted handle surfaces and polished chrome surround
  5. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Rear View Mirrors
    Some paint does come off - other areas don't budge:
    The driver's side front mounting thread was half broken - I decided to thread through and fill the outside hole later.
    I made a pilot hole bolt to drill the core hole and fabricated a new, longer bolt:
  6. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  7. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    driver's side door loom restoration - looking bad before
    sheaves removed - hard and potentially dangerous work as some of them are rock hard, very tight around the wiring and brittle - it's easy to cut your hands or slip with your scissors/knife...
    cleaned
    retaped and ready
    Tape used to refinish the looms:
    It's advisable to use a small cable tie where the wires exit the tape.
  8. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Column stalks normally functional but cracked: Image Unavailable, Please Login
    wiring has some issues too:
    Packed and shipped out to Verell:
    All repaired and ready to be refitted
    But - the ground wire for the horn switch is too short:
    Lengthened so it doesn't rub on the column
  9. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  10. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  11. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    1 word : epic !
  12. ronfrohock
    ronfrohock F1 Rookie
    4,181
    MA
    Ron Frohock
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Horn story - never worked reliably and sounded funny... finally down to 1) kinked hose 2) inop low frequency horn 3) intermittent button. One plastic cap was missing too, so we reproduced using the original one:
    strip-down
    masked and primed
    paint
    new stuff
    Compressor tear-down, clean up and repaint Image Unavailable, Please Login
    label reproduced by myself
    sealant
  14. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  15. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    The Engine/Gearbox needed attention. Among the items were a leaking clutch slave, noisy front cover cam belt bearings, valve clearance check, new diff exit bearing, lots of new gaskets and seals, and an interesting discovery: A missing roller on the gearbox input shaft bearing. See image later. A major service with some additional repairs. Lots of parts required:
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    ellum likes this.
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    engine out: Image Unavailable, Please Login
    gearbox removed
    oil pan
    transfer box and front cover
    Missing roller in the main input shaft bearing... can't fall out when mounted, so probably missing from new as their is no indication the gearbox has eve been rebuilt.
    very important small gasket:
    diff output shaft bearings
    new water pump of course
  17. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  18. ronfrohock
    4,181
    MA
    Ron Frohock
    This information is extremely valuable. I wish someone could snip parts of this post and add them to other posts to make them more robust. Example: The door window lift information you just shared should go into the existing post. I wish you had a Cabriolet as I’d love to see your documentation on the rear windows.
    I am in awe of what you are doing!
  19. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Now the bad news... improper storage of the interior during the body repair turned it into mouldy mess beyond reasonable recovery... so the decision was made to retrim all leather and vinyl parts. I spare you the images.
    I found a local company run by a superbly competent gentleman and decided to go ahead with the retrim after we agreed that the only way to do it was "original" = material, colors, textures, all stitching identical to original.
    So I stripped everything to individual parts and delivered them:
    We ordered leather in Italy with the correct color - on the right the original color sample, in the middle the vinyl chosen and on the right the new custom color leather:
    The original color carpet was sourced as well:
    and off-white (1000) thread color selected for the dark grey vinyl stitching:
    Everything was stripped and luckily, the foams have survived in very sound condition:
    The rubber bands supporting the front set cushions were all broken and got replaced:
