Sometimes a Breaker Bar is Just Not Long Enough | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by AEHaas, Dec 7, 2010.
  1. Rifledriver
    37,367
    #26 Rifledriver, Dec 9, 2010
    Ferrari insisted on the alloy nuts being dry. I have seen dry graphite or moly lubes work well.
    I use a very long cheater bar, its a little easier on the nuts but I have had to resort to a 1 inch gun too. When you have a six or eight foot bar, the car on the ground, someone inside standing on the brake with all their might and the wheel is still turning and the pile of broken tools is mounting you have to get mean. We have broken good quality torque multipliers and 3/4 square drives off like they were made of lead. The Ferrari wheel sockets are tough though. Never broken one and boy have we tried.
  2. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,541
    Raleigh
    Kevin
    Why not the air gun right off the bat?
  3. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    #28 PAP 348, Dec 9, 2010
    Heavy duty..........heavy duty. :eek::eek:
  4. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    What is the wheel lug supposed to be torqued to originally?
  5. Rifledriver
    37,367
    It doesn't do the sockets any good and the big, expensive alloy nuts come out looking like they got beat on with a hammer. At $600 each it pisses the owner off.
  6. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    #31 jm3, Dec 9, 2010
    Hard to find. SERIOUSLY clever. The axle nut is rotated (via gearing) around the arc that is bolted to the lugnuts.
    http://www.youtube.com/watch?v=66PeguKXnds
  7. Rifledriver
    37,367
    680nm on an F50.
    The others I don't recall without looking them up.
  8. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    cool tool. i went out today and cussed at the nut. it still has refused to budge. tomorrow i plan to threaten the nut with the air grinder. perhaps seeing the implements of its destruction will loosen its resolve.
  9. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    I will have to look up the torque once I go to put them back on but 680 NM sounds about right. Not sure just now.
    I need to get somebody to hit the brakes as the tires just spin now. I will probably get to it some time this weekend.
    Ferrari Tampa Bay said that should do it, but offered to put the 1 inch drive air gun to it if needed. Apparently it is always a pain. I know this from my own past experiences, so does everybody else it seems.
    Anyway, the point is that the wheels need to have the nuts moved periodically, probably yearly would be good.
    Note: the torque wrench is bigger than the breaker bar. It has got to weigh over 30 lbs.
    aehaas
  10. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    #35 ernie, Dec 9, 2010
    That is seriously badass!
  11. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    I agree with Brian on dry lubes and was never really concerned about those with lock plates. All I felt was required on those was to be sure the nut was in full contact with the wheel and a smooth torque was applied. The F40's without locking plates, those present special needs and attention.
    Agreed on yearly service of the nuts. A good bit of time has been spent wet stoning burs off of gauled wheel nuts that were ignored.
    I have two of the torque wrenches, each cost more than the 1" impact! Hard to believe a tool that big can be so precise, the old ones are a piece of art, like an old pocket watch!
  12. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    "Forward Off, Back On" is the phrase to remember.
    I use a spray teflon on the thread of the axles after very thoroughly cleaning of nuts and axles, then an accurate (very expensive) torque wrench. Still tough to get em back off.
  13. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,679
    Toronto / SoCal
    Rob C.
    You could always jamb a piece of 2x4 in the wheel spokes redneck style :D
  14. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    OK, I got the wife to help out and hit the brakes. I first applied pressure to get the wheels tight up against the chocks then she hit the brakes to keep the wheels from turning. Using my new 8' breaker bar I applied steady pressure for about 10 - 15 seconds (no jerking) and then the nuts started to loosen gradually . There was no snapping, just a gradual release as you would want.
    I then tightened them back up. The service manual says 640 NM but I only put them back on at 580 NM. In a few months I will change the oil. Then I will take the wheels off completely but for now it was just to crack them loose.
    aehaas
  15. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,257
    Huntsville, AL., USA
    Andrew
    If they're now not as tight as the manual says they should be, will you still be driving the car or just shuffling it around the driveway?
    All the best,
    Andrew.
  16. REMIX
    REMIX Two Time F1 World Champ
    That's a pretty cool breaker bar - but does it function as a torque wrench as well? What does 580nm translate to in ft lbs?
    RMX
  17. GuyIncognito
    GuyIncognito Ten Time F1 World Champ
    100,785
    427 ft lbs
  18. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    I built electric trolley cars for a while, we had to test the ebrake system to 1,000 foot pounds before putting it on the street and only had a 6 foot bar...
    I didnt weigh enough at 150 and had to have a buddy help push.... yes it was a serious torque wrench.
  19. Yoric
    Yoric Formula Junior
    385
    Yoric
    Yet another reason to be skeptical of the Ferrari myth--as in, what were they thinking when designing, manufacturing and selling to the public a car that needed a $3K belt change every 3 yrs (3x8) back in the 1970s, and a 21st century car that needs a 10 foot pole (sorry, breaker bar cum torque wrench), the Enzo, to change a wheel, as well as a wheel that must be removed and replaced every yr! What were they thinking indeed, other that their engineers had been drinking too much Lambrusco or that they wanted the official dealers to have an owner built-in captive audience. We must be nuts to go along with this m.o. He*l, the more I think about it, if anybody is interested in a 40K mile 1977 308 GTB with all services done within the last two yrs (belts, bearings, hoses, distributors, Webers), let me know, I may just be in the mood to sell before it's due for the next "regular maintenance." Sheeeesh!
  20. Rifledriver
    37,367
    Then wtf are you doing here?
    Why don't you go try Toyota chat twerp?
  21. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    +1
  22. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,287
    Illinois
    How much "weight" do you think you put on the bar? If it was 100lbs, that makes for 800LB-Ft of torque to get the nut to move. If the book says 640NM (472LB-Ft) that probably could be about right considering just a little bit of dirt or corrosion can significantly increase the resistance of the nut to turning.
  23. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    'A guesstimation only - I put maybe 75 lbs on the end of my bar extension for the rear wheel nuts and less, maybe 50 lbs on the front. I am not sure why the front nuts came off easier.
    aehaas
  24. Buxton
    Buxton Formula Junior
    Oct 31, 2010
    484
    B Buxton
    Isn't there an Allen screw in the cap to make sure it does not back off?
  25. cobmw
    cobmw Formula Junior
    466
    Rocky Mountain area
    It's got nothing to do with wheel nuts, but in the photo of your lift there are plates bolted to the floor. Are they for securing the lift? Did the lift manufacturer specify them? My lift is secured just around the base. I've always wondered what keeps it up.
