Source for Factory 328 Ignition Key Blanks | FerrariChat
Discussion in '308/328' started by maquino, Jul 19, 2005.
  1. maquino
    maquino Karting
    Jun 22, 2005
    219
    When I acquired my 328, the original ignition keys had been lost and I am working off a set of generic keys provided by a lockshop. But I would like to get a set of the original "hinged" black plastic ignition keys.
    The local Ferrari dealer advises that these blanks are no longer orderable. In their place are non-hinged blanks with near-circular black plastic tops and a tiny chrome cavallino inset on one side. I gather these were originally made for the 348/355 and are supposed to retrofit the 328.
    However they don't, quite. The groove is a hair off, and the blank is a little too long. When I had one cut, it works, but only sometimes & sticky. The generic key works smoothly.
    Anyone know a source that might have those original 328 key blanks? Thanks in advance. :)
  2. Gary Res
    Gary Res Formula Junior
    Apr 23, 2004
    573
    Long Island,New York
    Gary
    try E-bay
  3. MARQ
    MARQ Formula 3
    Feb 9, 2002
    1,924
    East Coast US
    Marq
    The key you are describing was also, I believe, made for the F50 and should be a direct replacement as a spare for your 328 key.
    Sounds like you had a bad cut done on the key. I use this key as a spare and it's operation is as smooth as silk;operates exactly as original key.
  4. tvu
    tvu Formula 3
    1,367
    Southern California
    Trieu
    I would agree with MARQ. Mine works perfectly, and I use it as the primary key.
    As for the folding one, would this one work?? It's for the 512TR, but it's the only hinged key that came to mind.
    http://ricambiamerica.com/product_info.php?cPath=16&products_id=27&osCsid=0af17e172db068582100ca73590493af
    Good luck.
  5. PerryJ
    PerryJ Formula 3
    Jun 5, 2003
    1,909
    N. Alabama
    John Perry
  6. maquino
    maquino Karting
    Jun 22, 2005
    219
    That looks like it, all right - Thanks! :)
    BTW This is the ignition key immortalized in the Automobilia book on the 328/Mondial 3.2 thus: "... The ignition keys, however, are as ugly and depressing as usual. Unmistakably Ferrari, sure, but 'poor' compared with what Porsche and BMW offer ..." The same review goes on to label the absence of a glovebox in the 328 as "scandalous", but at least expresses relief that the car has an analog clock instead of one of "today's hateful digital clocks". :D
  7. maquino
    maquino Karting
    Jun 22, 2005
    219
    Well, I got two of the folding-blanks from Daniel Pass of Ricambi (a very nice and helpful gentleman, BTW), but they turned out not to be usable, as they are for the Testarossa (designed for 2-sided, not 1-sided cut). He doesn't have the 1-sided hinged blanks, so I am still looking for them.
    As for the round-headed keys with the silver cavallino on them, there remains a question about them. I have a couple that were cut exactly the same as the generic key that came with my 328, but they work only sometimes, and often sticky. My locksmith showed me the differences in the slotting of these keys and the generic one, and thinks this is the problem. (He has not examined the actual ignition lock itself yet, which is the next thing on the agenda.) I would rather have an ugly key that works all the time than an elegant one that only works sometimes!
    I have fired off some queries to other Ferrari.com sponsors about the desired blanks, and will check eBay as suggested. Any other leads I would welcome. :)
  8. gil308
    gil308 Formula 3
    Jun 22, 2004
    1,975
    Charleston, SC
    Gil
    I bought mine many years ago and never had any problems. At the time, they were $20 from Algar Ferrari. They had 5 in stock, so I bought them all. Really looks nice with the tiny Cavallino.
  9. PWehmer
    PWehmer Formula 3
    Oct 15, 2002
    1,733
    Surrounded by Water
    GT Car Parts had the single sided folding key blanks not to long ago. Very reasonable cost also. Work great in my 328.
  10. MARQ
    MARQ Formula 3
    Feb 9, 2002
    1,924
    East Coast US
    Marq
    This is definitely the recommended replacement key. I've had a couple o' spares made from these blanks and have never had, nor heard, of problems with them working. Hmmm....doesn't make sense. The slotting on the Cavallino key may not match the generic key you've been given with the car (and have been using) as the generic key may not be a correct match for the original/correct key. I just compared the 'slotting' on the oringal key with the slotting on the Cavallino key and they are dead-on identical. My opinion is still that you, somehow, got a bad cut on the key.
  11. maquino
    maquino Karting
    Jun 22, 2005
    219
    Got another of the "F50" (black near-circular head with silver cavallino) blanks and this time had it cut from a computer reading of the key code in the car's warranty booklet. Works perfectly.
    It would seem that this should have been done previously. However, when I took the "generic" key which came with the car to an earlier locksmith, he checked the computer code and said that it bore no relation to the cuts on the generic. So I was back to working off the generic, and apparently cutting the factory blanks using the generic as a source was a no-go.
    The solution was a different locksmith who evidentially did not have his head in rectal defolade. Even so, this new locksmith looked at the computer-cut key and said, for whatever reason, "This doesn't look right to me." (Not that he computer-cuts Ferrari keys every day!)
    Anyway, problem solved. Pretty key with pretty cavallino. :)
    Thanks to all of you for your comments and suggestions. :) :)
  12. MARQ
    MARQ Formula 3
    Feb 9, 2002
    1,924
    East Coast US
    Marq
    Glad to hear it...
