Source for new Door /Targa Roof seal. GTS | FerrariChat
Discussion in '308/328' started by 308 milano, Sep 17, 2015.
  1. 308 milano
    308 milano F1 Veteran
    5,351
    Montana
    Kim
    Anyone know where I might find original door/roof seals for an 82 308 GTS without being bent over too badly? Even quality reproductions would be fine, keyword " Quality " can't tell you how many other items I've had to return to the usual source's as the piece was just cheap or extremely poor fit or finish. Tried using the "search function " but death would probably come sooner then success. Thanks in advance.:)
  2. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    Reoriginals
  3. Jeff328
    Jeff328 Formula 3
    Sep 5, 2006
    2,293
    WI
    The seal that goes around the bottom of the doors and over the back part of the roof opening is a standard profile piece and should be still available from the dealer. I got one from Lake Forest Sports Cars in IL for about $40 a few years ago.
  4. Rifledriver
    37,288
    The big long piece around both doors and the rear of top opening is cheap as has already been said. Usually sold by the meter.
    The top side seals and the top front seal or header seal have never been cheap.
    The side seals take quite a bit of fussy fitting prior to gluing them in place.
    The header seal used to be NLA but I think it is being reproduced. I have a new original if you get stuck but it will be expensive.
  5. 308 milano
    5,351
    Montana
    Kim
    Guys are you kidding me? LOL I figured the price for the long piece that goes beneath both doors and then up over the rear Targa band would be at least $400 on a good day! $40? Oh yeah! Brian, the header piece above the front windshield is still good but I do need the two strips that glue on the removable top above both left and right door glass. Anyone have a set or know who I should call? You guys just made my day! Even at $100 I would consider it a good deal for that long piece of rubber!! Seriously, thank you
  6. scudF1
    scudF1 F1 Rookie
    2,919
    Long Island, NY
    Billy
    Don't forget the Ferrari taxes.
  7. TacElf
    TacElf Formula 3
    Aug 15, 2010
    1,719
    Seattle area
    Jeff
    The top-front seal was being reproduced by andyww here on FChat. Don't know if that is still the case. I picked one up a year ago just in case.
  8. Matzo88
    Matzo88 Rookie
    Jul 27, 2014
    20
    Germany
    Joachim
    Hi,
    probably you guys already know it... but here you can get some 308 rubber parts: www.cicognaniguarnizioni.it I have never ordered there so can't tell anything about the quality because until now the rubbers on my car are just fine.
    Regards, Joachim
    Vandergoode likes this.
  9. 4redude
    4redude Formula Junior
    Jan 13, 2005
    733
    Fungus Corner
    Brian Keegan
    Ferrari part number for the lower door/rollbar rubber gasket is 6170550 and should be readily available.
  10. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,354
    Send a PM to Andyww, he had the front Targa seal remade
  11. EP328
    EP328 Formula Junior
    622
    Northern California
    Ed
    Couple years ago I got the top side seals from Ferrparts. Don't recall price.
  12. CT 328 GTS
    CT 328 GTS Karting
    Jan 31, 2006
    112
    Connecticut
    Steve
    Ricambi has them for about $160. Go to their site and type in 6170550.
  13. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    MrFiat.com has many Ferrari item as well.
  14. 308 milano
    5,351
    Montana
    Kim
    WOW! Thanks for all the information guys!
    Ep328 The rubber top seals that go above the left and right door glass, how do you like them? Do they seem to be holding up OK and a quality product? Thanks
  15. EP328
    622
    Northern California
    Ed
    They are fine. I had an upholstery shop install them when the interior was done 2 years ago.
  16. 308 milano
    5,351
    Montana
    Kim
    Thanks! Will give Puno at Ferrparts a call tuesday and order up a set if still available. Will get the Door rubber coming also but I wont be Home for another 10 days and need to see how many lineal feet I need to order . Thank you Guys.
