Source for oil cooler pipes rebuild ? | FerrariChat
Discussion in '206/246' started by Skippr1999, Aug 18, 2017.
  1. Skippr1999
    Skippr1999 F1 Rookie
    4,508
    #1 Skippr1999, Aug 18, 2017
  2. swift53
    swift53 F1 Veteran
    8,284
    E.S.
    Alberto
    Closest guess, is Europe....
    Good luck!
    Regards, Alberto
    PS. If not in a big rush, like by November, I can arrange something.
  3. absostone
    absostone F1 World Champ
    10,024
    Word of advice. Put them back on the car and mark the hose to the fitting. Go to a place that deals with hoses like forklifts etc. they can re use the fittings so I thought based on fchat. When I went to put them on they would kink and also I found out that the portion that goes inside the hose gets kinked So what they actually do is cut off the internal portion and reweld the part then put the new hose on. Keep in mind that it may take some time for the hose to relax and not have a slight kink. And a note on the size, one day I went to 4 places to try and remedy the problem and no one could help especially cause of the metric original fittings. So I put them on and so far so good
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,955
    Isle of man- uk
  5. Skippr1999
    4,508
    Thanks for the responses. I'm going with the Superformance steel braided version. The car is on my mechanics lift occupying space, so I don't have time to sort this one.
    My thoughts are:
    Important part for oil flow !!!
    USA hydraulic shops don't have metric hoses
    USA hydraulic shops don't have the correct crimp fittings (Ugly !)
    What's the point if it won't look original once done
    If there was a way, Superformance would have already done it most likely
