Source for Part of Headlight Cluster - 360 | FerrariChat
Discussion in '360/430' started by tomoshea, Jul 10, 2014.
  1. tomoshea
    tomoshea Formula Junior
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    #1 tomoshea, Jul 10, 2014
    Does anyone know where I can source a replacement for the 360 headlight alignment adjuster mechanism (the up/ down tilt mechanism shattered/ broke on me while adjusting) - the white mechanism in the photo below.
    It isn't listed as a separate part on the Eurospares website.......
    This must be a common part and not just Ferrari specific, guy in the garage said he had seen it on Lambo headlight clusters also, wondering if it is a common hella part?
    Any guidance appreciated.
    Cheers
    Tom
  2. Sled Driver
    Sled Driver Formula Junior
    May 13, 2010
    494
    Stokesdale, NC
    Emery
    Unfortunately, this part is not available separately from Ferrari or Hella. I contacted both companies a couple years ago with no luck.
    Over time this part becomes extremely brittle & crumbles to pieces if you touch it.
    Checking eBay for used 360 light assy you’ll find this part is often missing.Talking with Ryan @ exotic auto recycling he has had little success trying to salvage this part from used headlights for customers. Instead sells the complete used light assy.
    A new light assy will set you back $3-$4K . Russ @ Ferr Parts may be able to source you a Euro light (non HID) or odd color for a little less to use for parts (still around $2K)
    Awhile back I purchased a used light that “looked” like it had a good adjuster. During unpacking I found the base cracked. I epoxied it back together, but it crumbled during installation. After gluing it two more times I gave up.
    I ended up making an aluminum base that uses all the stock internal parts…shaft, gears. The stock top cover is retained with roll pins. So it looks stock, but is much stronger.
    I had to remove the headlight assy from the car to install the backing plate for the aluminum base to screw into.
  3. freaky1
    freaky1 Formula Junior
    Dec 10, 2012
    434
    Sydney, Australia
    Paul
    This part looks like a good candidate to be scanned and 3d printed
  4. 993man
    993man Formula Junior
    878
    New Zealand
    Graham
    Now that is a GREAT idea.
    Those 3D gizzmo's are affordable as well now.
    We can all buy a 3D thing and start making them, and selling them to Ferrari, but make sure they go sticky before they break so they know what it's like.
  5. tomoshea
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    Thanks for the update.
    I have managed to create a solution that was adequate to get it through the annual road worthiness test we have here in Ireland, but will need to craft a more permanent solution.
    Mine shattered into pieces and it held together with JB weld and other epoxy materials.
    Unfortunately I didn't see how the white bit was mated to the grey body of the light pod, do you have any pics of that/ measurements or pictures of your solution so I can see how I go about building something more robust for the long term..... as I just had the headlight pods refinished/ polished and cleaned inside I have no intention of forking out for a replacement pod.....
    Cheers
    Tom
  6. 993man
    878
    New Zealand
    Graham
    Seriously Tom, look at a 3D printer. After freaky1's comment I went on line and checked them out.
    Not only will they make a replica, they are cheap. Over priced Ferrari parts 'could' become a thing of the past.
    Then I got to thinking, no, really, why couldn't I buy one and make all those sticky buttons again?
    Unless there's something I'm missing this could be a great thing!
  7. tomoshea
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    No problem with that but I need a pattern to work from.
  8. freaky1
    Dec 10, 2012
    434
    Sydney, Australia
    Paul
    I've been privy to see a number of different plastic parts being 3d scanned , then 3d printed for our cars.
    It's the way forward without having to pay exorbitant costs to Ferrari.
  9. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    #9 English Rebel, Jul 11, 2014
    Myself and a few other enthusiasts have constructed a replica of a Lear45 cockpit for a flight simulator and these knobs for the flight guidance computer (autopilot) were made on a Solidoodle 3D printer. As was said -- all you need is an original to make a CADD file from.
    Alan
  10. tomoshea
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    I don't have a complete original part unfortunately...
  11. 993man
    878
    New Zealand
    Graham
    Yeh but someone will have one that you can use.
    Just take a 360 out form the dealers and do what needs to be done. Or another 360 owner might help.
    For me, I'm buying a scanner this week and I'm remaking those awful sticky parts. Or at least, I'm going to give it a go anyway.
  12. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,509
    Honolulu
    Kevin
    Graham, the sticky parts are brilliant once you get the sticky stuff off of them! Use your energy wisely!
