Source for safety wire | FerrariChat
Discussion in 'Technical Q&A' started by FasterIsBetter, Aug 12, 2008.
  1. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Does anyone know of a good source for stainless steel safety wire? I'm assembling some two piece brake rotors, and the bolts need to be safety wired. I need 0.032" wire, must be stainless. None of the local auto parts places seem to carry it. Any ideas where I can find it?
    Thanks,
    Steve
  2. stephenofkanza
    stephenofkanza Formula Junior
    Mar 5, 2005
    542
    Kansas
    Stephen LeRoy Sherma
    Do you have an airpot with a FBO (Fixed Base Operator) (place where they work on planes) nearby?
    They use it all the time and I'm sure they will sell you a spool, od give you a few feet.
    Stephen
  3. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Google racer supplies..
    Or, Aircraft Spruce, Wicks Aircraft Supply, Earls, Pegasus, Truechoice, Racer Wholesale, Motorsport Spares, et al
  4. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    #5 KKRace, Aug 12, 2008
    I've even seen it at Harbor Frieght. Check the local motorcycle shops too. Or any racer or raceprep shop will give you a few feet. Don't forget Summit, Jegs etc but Pegasus had a good price on it last time I checked. Do you have the safety wire plyers? The motorcycle racers are required to safety wire certain items so a lot of the local bike shops sell it.
    www.pegasusautoracing.com
  5. 350HPMondial
    350HPMondial F1 Veteran
    5,333
    Edwardo
    McMaster-Carr
    92705K14
    Type 316L Stainless Steel Wire .032" Diameter, 1/4-lb Coil, 91 ft/Coil
    In stock at $14.03 Each
  6. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    Lifetime supply.
  7. f1 fanatic
    f1 fanatic Rookie
    Nov 15, 2005
    33
    Rancho Santa Margarita , CA
    martin
    acceleration kart racing in Vegas
  8. FasterIsBetter
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Yes, thanks. We ended up ordering it from them, along with a 12 pt. socket needed for the bolts.
    Someone said lifetime supply. I'm not so sure about that. This is for Wilwood two-piece front and rear rotors. Each rotor has 12 bolts x 4 rotors. Since the car is used extensively on the track, I expect to go through two sets of front rotors a year, and one set of rears. Should be interesting to see how long the wire ends up lasting.... or more interesting, how long the rotor sets end up lasting.
    Thanks for all the responses, gang!
  9. dozzina
    dozzina F1 World Champ
    10,496
    In a vortex
    Dave
    The 316 (which is supplied in hard temper) is probably not the best choice. The McMaster site responds with this to "safety wire" as a search:
    Material Multipurpose Stainless Steel (Type 302/304)
    .032" Wire Diameter
    20 AWG 1/4 lb. Spool 91' 8860K14 $7.06
    Still a lifetime supply.
    (I love McMaster-Carr, but I got my safety wire years ago at Harbor Freight.)
  10. dozzina
    10,496
    In a vortex
    Dave
    Dang, just a bit too slow.
  11. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,659
    Toronto / SoCal
    Rob C.
    When doing the wiring make sure that the safety wire is threaded in such a fashion so that if a fastener wants to loosen, the wire tries to tighten the nut next to it.
  12. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    If you don't get Safety wire theres a good chance what you get will break or be damn near imposible to twist. It's cheap enough from Pegasus. Buy the pre drilled bolts from them too. Trying to drill grade 8 bolts is not fun. I have one roll from HF and one from Longacre racing. They are in the same container and came from the same plant. Only problem is HF only has the thick stuff.
  13. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    my wife got it so I'll share ... Harbor Freight "safety" wire is an oxymoron :)
  14. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Yeah. I buy things from Harbor Freight (China) but NOTHING In would want to bet my life on!
    An FBO at an airport is your best bet.
  15. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    cheers
  16. 350HPMondial
    5,333
    Edwardo
    Hey now, , , this is a Life or Death piece of lockwire.....!
    (My bad , , listen to Sean... 304.)
    We use 316L in Nuclear Power.
    We used 0.032" Monel,
    on our missiles..back in the 70's
    If my life depended on it, , , I would use steel wire.
    Or....?
    Edwardo
  17. tazz99
    tazz99 F1 Rookie
    4,471
    Kennesaw, GA
    Seth
    Don't forget to get a pair of safety wire pliers if you don't already have them.
