430 - Sparco aftermarket seat installation | FerrariChat
430 Sparco aftermarket seat installation
Discussion in '360/430' started by colorfull, Mar 14, 2023.
  1. colorfull
    colorfull Formula 3
    2,281
    Franklin Park, New Jersey
    John Napoli
    OK, so this was really a time consuming project which would have not taken nearly as long, but spent a lot of time trying to find information about how to do this. If I can help anyone in a similar situation, feel free to reach out.
    Firstly, many thanks to @LorenzoR, as I was going through this process, so was he, in fact I was trying to keep up (as usual), as we collectively worked through, I couldn't have done it without him. Also many thanks to others who helped with the problem solve and contributed including @mwstewart @Qavion @GCalo @Flea7 @clean512
    A couple caveats, if you have a US car with a COPD sensor in the passenger seat, there is a connector coming from the floor which connects to the sensor. Once you remove the sensor, you will likely get an AIRBAG light on the dash, though someone reported this not happening on an early model car. AIRBAG discussion is too complicated to go through here, if you have questions, feel free to PM me. In short, the best solution I would suggest, which Lorenzo implemented, is purchase a CPOD, install it in your manual seat and connect it.
    My seats are Sparco SPX that have been re-leathered. They have holes in the base for seatbelt mounting, very convenient, not all have these. If you don't have seatbelt mount holes, you may need something different.
    If you have Ferrari seats, or seats that have rails the same width as the floor holes, this would be a lot easier. You shouldn't need a mating bracket.
    The Sparco seat rails are more narrow than the floor holes, so I made a custom plate that mated the two. This was as low down as I could get the seats to the floor.
    They came with the Sparco 600 brackets, but they are heavy, have 'wings' that ate into the center console leather, and raised the seats almost 2", hence the below approach.
    Make a template
    First thing I did was get measurements of the floor holes, and make a template out of thin plywood, available in Home Depot, usually sold as sub flooring plywood, like 3/16" thick. This allows you to get your holes as close as you can to where they should be, then make the holes in the template, and install the seat to the floor and actually use them to adjust forward/back slide distance. Where you place the holes will determine minor forward/rearward closeness to the pedals.
    Custom plate
    Once I had the dimensions set, I made up a spec drawing, brought it to a metal worker, and had him make the plate.
    I had to countersink the holes in the rear underneath the plate so they would clear the raised floor mounts. In the front, regular bolts were fine.
    Once I got the plate back from the shop, I painted it black with gloss paint and glaze to make it look high end. Then I wrapped the edge with door edge guard that I got off Amazon. Looked really nice.
    Mounting
    Then, the plate got mounted to the bottom of the seat. All of the bolts, nuts and washers are black, I wanted them to look matching. Was a pain to find them all, but once I started, had to get them all.
    Unfortunately, the front area of my carpet in front of the rails is cut out, no idea why, so still have to patch that or cover it somehow (open for suggestions). Ferrari sells a cover for the rail tips for sport seats, but with the way I designed the bracket, they don't fit as the bracket is in the way.
    Hard to believe this is a fairly simple write-up considering the months it took to get information, try out different configurations, figure out the airbag, talk to seat bracket manufacturers, etc.
    I've got lots of pics of details of the install, let me know if you want to see any of them.
    Best of luck with your install!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    robst, PKIM, cavlino and 6 others like this.
  2. colorfull
    colorfull Formula 3
    2,281
    John Napoli
    Here is a PDF of the drawing, I did it in Visio, if you want the visio file for editing, PM me, FCHAT doesn't allow upload of visio files looks like.
    mwstewart likes this.
  3. collegeboy
    collegeboy Formula 3
    1,317
    Texas and Kaua’i
    Mikey
    Looks really good!
    colorfull likes this.
  4. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,753
    England
    Mark
    Great result John.
  5. AandSC
    AandSC Formula Junior
    921
    Jax, FL
    Allen
    LOVE those seats! Really nice work! Thanks for sharing your efforts. Although I’m unlikely to ever swap my seats out I have to say I would do exactly this if I were to.
  6. Steve Heck
    Steve Heck Formula Junior
    Nov 1, 2021
    262
    TO Canada
    Steve Heck
    Excellent John, and thanks for the suggestions on my build thread !!
    Cheers
    Steve
  7. colorfull
    colorfull Formula 3
    2,281
    John Napoli
  8. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,153
    Wash DC area
    Robert
    Lovely car!! The yellow calipers really make it pop!
  9. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    Those seats look AMAZING !!!!!!!!
  10. lowform
    lowform Karting
    Feb 25, 2021
    88
    Peoria, AZ
    Aaron
    Fantastic outcome! Thank you for sharing the process. I hope to so this in my car one day.
  11. 2Di4
    2Di4 Rookie
    Feb 5, 2022
    3
    Massachusetts
    Paul Zee
    Do they feel as good as they look?
  12. colorfull
    colorfull Formula 3
    2,281
    John Napoli
    Actually they do. I find the electric Daytonas ridiculously comfortable. These are not as cushy, they are firmer, more supportive and more secure holding you in place, and to my arse and back, feel even better. They feel pretty perfect imho.
  13. Zack Hawker
    Zack Hawker Karting
    Feb 27, 2018
    132
    Paradise Valley, Az
    Zack Az Realtor
    Do they sit lower than the Daytona's? I have been lurking for 2 years trying to replace my seats and have read every seat thread but I seem to get no where.
    I am 6'4" and need to lose an inch or more.
    Any input is appreciated.
  14. colorfull
    colorfull Formula 3
    2,281
    John Napoli
    Great point, this was a particular issue for me and prompted this whole effort, and I had the same experience, very little info on this to be found.
    The daytonas sit really low. Ferrari can put them low since they spec them for this car.
    For commercial seats like Sparco, they make them to fit in many cars, and so they don't make them as low since in most cars they would be too low.
    These do not sit as low as I installed them, seat surface is maybe 1-1.5" higher Than Daytona. I didn't measure, I go by my eyeline.
    The seat cushion is about the same thickness as the daytonas, it is just higher in its base, so the only way to get the surface of the seat lower would be to use floor mounted brackets, no rails, fixed mount.
    I considered this since I rarely move my seat, but wanted sliders and I'm kind of liking it a bit higher.
    I'm 5'9", my eyeline is about 3/4 of the way up on the windshield which I like, I thought I was actually too low in the daytonas, felt like I was looking at the steering wheel and dash, not the road.
    If the daytonas are a good height for you, or even too high as you state, I would think you'll have to find a seat specifically designed for a low seat surface (maybe racing seats?) and a low bracket situation.
    I can take measurements if you like of mine.
  15. Zack Hawker
    Zack Hawker Karting
    Feb 27, 2018
    132
    Paradise Valley, Az
    Zack Az Realtor
    Thanks for the detailed reply.
    If you are bored at some point and want to measure I would be curious. But I have a coupe, so I'm sure the roof is not the exact same height.
    I have 36.5 in from the roof to bottom of the Daytona. Bottom being where your butt sits.
  16. colorfull
    colorfull Formula 3
    2,281
    John Napoli
    You got it
    I was thinking measuring from the floor to the top of the seat, since to your point, we have different roof heights I expect and that is the dimension you want to reduce and look for in other seat options
  17. Flea7
    Flea7 Formula 3
    1,962
    PNW
    SKIM
    Excellent John!!! Those seats look fantastic!
  18. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,753
    England
    Mark
    I found that I sat 'on' the stock seats rather than 'in' them. I had a 430 with standard seats and another with standard plus power & heat. I could be wrong but the power & heat versions felt even higher. As a taller driver myself I found the shoulder support was in the wrong place as it ended below by shoulders.
    A sport seat upgrade like John's will be night and day for a taller driver.
    Flea7 and colorfull like this.
  19. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    Now being 5'6" I don't need to worry about seat height, but...
    I'm going to say a controversial statement here...
    I wonder how much of the driving experience of the 430 Scuderia is due to the sports seat buckets over the standard seats being deeper and that you sit 'in' them over the stock seats you sit 'on'
    I was having a conversation with John earlier this week about the difference between my F430 and my 996 GT3. I told him the GT3 feels more like an extension of me vs my F430. Yes, the GT3 has a much tighter steering and suspension over the 430 but maybe the factory GT3 cup seats are a "butt dyno" part of the reason. Like John's Sparco's you really do sit 'in' them vs normal seats which you sit 'on' and then are held in by bolsters. Never really thought about this seat aspect till I read your post above. BTW: You should see how deep you sit when in track mode where you remove the "comfort" cushions to allow extra helmet room.
    I don't really have any good pics of the seats that show how deep these things are because they are installed in the car so here is a picture of 996 GT3 seats from bringatrailer.com
  20. colorfull
    colorfull Formula 3
    2,281
    John Napoli
    Wow @CoreyNJ , those look like your butt sits on the floor! Zach, this is the kind of thing I was talking about to get that extra height.
    Corey, you make a great point, I don't think you can understate that aspect of the driving experience, greatly impacts how it fells to drive the car when deeply supported and properly positioned, puts you much more in command, imo
    Sadly, I still have yet to experience driving a Scud, but when I do, I'll be sure and pay attention to that! :)
  21. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,753
    England
    Mark
    Seats certainly do change the driving experience: closer to the ground is always more fun. It's one of the reasons that karts and single seaters feel so much faster than a road car at any given speed.
    I've been considering removing the factory runners from my Scuderia seats and creating a mounting plinth similar to Johns. I think I can lower them by at least 1" and save more weight.
  22. colorfull
    colorfull Formula 3
    2,281
    John Napoli
    But will you be able to see over the dashboard at that point Mark? ;)
  23. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,753
    England
    Mark
    Ha ha hopefully, if not I'll end up with a sofa cushion on the seat :D
  24. Zack Hawker
    Zack Hawker Karting
    Feb 27, 2018
    132
    Paradise Valley, Az
    Zack Az Realtor
    John, we're you able to get that floor bottom of seat measurement?
    I'm remotivated to tackle this seat problem of sitting on and not in them. Can't wait to feel the difference as on longer drives I'm starting to get frustrated and ducking to see below the rear view mirror. It's ruining the experience.
  25. colorfull
    colorfull Formula 3
    2,281
    John Napoli
    Hi Zach,
    Apologies for not getting back sooner, I was in the studio
    So I get 4.75" from floor to top of seat, 6.5" - 1.75"
    This is meazured at the lowest part of the seat, the stripe closest to the seat back
    Flea7 likes this.
