430 - Spark plug coil packs different on some F430s? | FerrariChat
430 Spark plug coil packs different on some F430s?
Discussion in '360/430' started by Mercedes_Benz, May 1, 2022.
  1. Mercedes_Benz
    Mercedes_Benz Formula Junior
    515
    South Florida
    Hi all,
    I am in the middle of still doing a lot of maintenance on my new to me F430. One of the things next up is new spark plugs. I watched a youtube video for fun to see it done (looks easy). But I see the 2 F430s I saw videos of, the coil pack is screwed down with an Allen bolt. I quickly looked at mine today, and I don't have any bolts? not even a hole for one on the valve cover. My car is a 2007, did they change something? or did I miss looking at something on my car? Here a picture of mine..
  2. Mercedes_Benz
    515
    South Florida
    In this video you can see the bolts on his
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,890
    Central NJ
    Dominick
    Changed somewhere in the middle of 2007 .. Assembly 68460
    tbakowsky and Mercedes_Benz like this.
  4. Mercedes_Benz
    515
    South Florida
    Thanks! you know your stuff! Wonder why the change? and do you know if these just pop right out? or need to be rotated a certain way or anything?
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    They just pull off, do one plug at a time so you dont mix them up.
    Re plug spanner, glue the rubber sleeve into the socket so it does not end up on the plug, also you can get a 3/8 torque wrench in,, if you cut down the length of the extension bar so the torque wrench will fit the aftermost plug- then weld the socket to the extension bar.
    flash32 and Mercedes_Benz like this.
  6. Mercedes_Benz
    515
    South Florida
    Thank you. I will check the access and see while I am doing it if I can try your method. Any idea why they made this change? I assume the plugs are the same on all anyway.
  7. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,421
    Santa Clarita, CA
    I twisted mine back and forth slightly when removing them. They came out easily.
    Mercedes_Benz and flash32 like this.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,890
    Central NJ
    Dominick
    Sane plugs
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    My plugs had 15000 miles on them from the build, the service interval is over 30000. Total waste of time and money taking mine out as like new. How many miles on yours as might not need doing
    Mercedes_Benz likes this.
  10. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    I just recently changed plugs on a scud. that had the pull out coils. They were pretty clamp down and some where difficult to pull out.
    Make sure that when you push them back in that they product a "snap" for assurance that they are installed properly.
    I don't know why they changed out the earlier models of using bolts but they are much easier to remove and install.
  11. Mercedes_Benz
    515
    South Florida
    My car has 19k miles. No record of them ever being replaced. I agree, they probably are fine, the car is running fine, but I am anal and just feel better changing everything. Don't ask! I know...
  12. Mercedes_Benz
    515
    South Florida
    Good info, thanks.
  13. Mercedes_Benz
    515
    South Florida
  14. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    I don't know about the ebay seller that you listed but I know many has bought from the ebay seller below, me included. I hope this helps.
    https://www.ebay.com/itm/154597870105
    Red 27 and Mercedes_Benz like this.
  15. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,421
    Santa Clarita, CA
    Last year I changed the plugs on my 2009 with 13,500ish miles. The car was running great and the old plugs looked great. I was just concerned that they’d been in the heads for 12 years.
    The coils came out easily and the plugs came out easily.
  16. Mercedes_Benz
    515
    South Florida
    Thanks, I just bought those. They were cheaper anyway since the listing I found was for 10.
    Flea7 likes this.
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    Take one out for a look and if ok just look and put back, at least you will know they will not be seized in the heads after many years of never being looked at. I could see no difference in the originals to new- gaps did not need adjusting either.
  18. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    I think 07 it changed, apparently its same coils as scud which i believe uses ionic knock sensing.
    probably to streamline production
  19. Mercedes_Benz
    515
    South Florida
    And after replacing the plugs, what is this re learn procedure or something I saw in the workshop manual. Should I ignore that and start the car and drive as normal? or is there a special procedure I need to follow?
  20. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    Just drive it
    There is some process you can do. but i really dont think its needed
    I felt no difference after new coils, plugs maybe slightly smoother
  21. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,890
    Central NJ
    Dominick
    Disconnect battery..let sit for 10 mins or so .. reconnect then follow this
    Self-acquisition of the Motronic ECUs works correctly when the intake air temperature is higher than 5°C.
    Therefore make sure the external temperature is not outside the value specified.
    Leave the engine running for approximately 10 minutes in the following conditions:
    car at a standstill with engine idling;
    water at operating temperature;
    all devices off (lights, wipers, etc.);
    air conditioner off.
  22. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    According to rifledriver, you just start it up and drive it. From what i understand the fuel trims will then adjust themselves i think he said. Makes sense as only doing plugs
  23. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,890
    Central NJ
    Dominick
    The re+learn procedure like that on many Ferraris( and many other makes) justs jump starts the process .. the system will adjust fuel trims eventually.. just quicker by doing procedure
  24. Mercedes_Benz
    515
    South Florida
    So basically just let the cart idle for 10 min.
    flash32 likes this.
  25. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,890
    Central NJ
    Dominick
    Just follow those small but key points above
