Spark Plug condition | FerrariChat
Discussion in '348/355' started by huzilulu, Dec 18, 2023.
  1. huzilulu
    huzilulu Formula Junior
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    Hey Guys
    I am on step 1 of my major: do a compression test before starting... I have decided to do a compression test on a cold (no italian tune up) engine, and then another after running engine a bit (Question: I have read not to remove spark plugs from an aluminum head when hot - but most of the 355 compression tests are done with a hot engine... any points of concern? should i be replacing the spark plug as quickly as possible?)
    I pulled of the plugs and saw the below (arrange in order as removed from car)... Clearly the bottom 2 plugs on both sides are corroding, and the corrosion is especially bad on the left side... Any suggestions as to why? I did notice that the right side had a rubber plug on the plug leads right at the back entrance under the plug cover plate... the left side did not have that rubber plug... Any points of concern that I should look for before taking the engine out (test anything before removal)?
    Thanks!
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    The corrosion is from water getting past the spark plug wire boots on top of the plug.
    Likely because the gasket over the spark plug cover allows water intrusion.
    {the alternate explanation is driving in the rain throws water up where the slug wires enter the cover.}
    When you put it back together use a new gasket.
    308 GTB and Qavion like this.
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    As Mitch said also sometimes oil gets in there if the rings between head and valve over are not installed perfectly
    Quite common
  4. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    680
    Continental Europe
    For so much rust to develop would require the car to sit unused for unreasonably long periods and/or stored in a rather wet environment and/or the plugs themselves are very old.
    I don't know for how long you have had this car but I sure wish her to be driven more regularly.
  5. huzilulu
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    Just bought the car a month ago... starting a complete rebuild (major, suspension bushes, steering rack, shocks/springs, anythign else i find along the way)...
  6. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    simple water intrusion into the plug area and allowed to sit/puddle from the cover/wire not well sealed. VERY common.
    Rifledriver likes this.
  7. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    Also illustrates the potential value of a dab of anti seize on threads with the potential of long term storage issues...
  8. Rifledriver
    37,082
    #8 Rifledriver, Dec 22, 2023
    Most plugs we use specifically say not to use antsieze and have for a long time. Besides how is antisieze on the threads going to have any impact on rust on the body of the plug from water intrusion?
  9. Rifledriver
    37,082
    Too many wives tales.
    Also there is so much debris on those plugs and down in the plug wells it is hard to imagine some of it did not get into the cylinders and on the valve faces making any compression or leak down test meaningless. Before any more disassembly screw in a new set of pugs, fire the engine for a minute or two, pull them back out and then do your test.
