Spark plug-extender combination for 1984 QV | FerrariChat
Discussion in '308/328' started by RichardAguinsky, Jun 4, 2008.
  1. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    My 1984 Mondial QV has black extenders with NGK BPGES plugs.
    My intention is to go Iridium. I found in the forum that the recommended plug is BPR7EIX or BPR6EIX. But these are resistive plugs that go with the red extenders. I have the black extenders in my car.
    Did a PO change the original red non-resistive extenders with the black resistive ones and changed the plugs to non resistive?
    Will I be ok with BPR7EIX plugs with the black extenders? I can't find Iridium non resistive, BP7EIX does not exist.
  2. Steve Magnusson
    26,876
    Don't rely on just the plastic's color to make a conclusion about the resistance of your extenders -- use an ohmmeter and make a measurement (for example, TR extenders are also black and have 0 Ohm resistance).
    Adding a little more resistance with a resistor-style plug won't cause you any trouble. It's using a non-resistor (0 Ohm) extender with a non-resistor plug that would be trouble -- this can stress, and blow-up, the transistor in the Digiplex firing the coil primary.
