Spark plug heat shields | FerrariChat
Discussion in '308/328' started by Crallscars, Jul 24, 2006.
  1. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    I am in the middle of changing the spark plugs on my 308, and I find what apears to be heat shields around the spark plug wire extenders.
    I am missing a few, and Brian at Rutlands says my car shouldn't have these heat shields.
    Does anyone else have these? They are a high temp mesh about 5 inches long with spring clips around the extender.
    What is the best to set the gap at?
    Doug
  2. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    They are not OEM. It's an aftermarket part a lot of racers use. I used them on my old FF2000 b/c the engine area under Formula cars can get quite hot the exhaust headers are so close are right on top of the plugs/wires at the head. Not really necessary on the 308.
    http://www.ferrarichat.com/forum/showthread.php?t=39303
    I use NGK BP6ES at .027 for stock ignition. .035 for electronic. Search "NGK BP" and you'll find lots of discussion on them.
