Spark plug tool | Page 2 | FerrariChat
Spark plug tool
Discussion in '308/328' started by VIZSLA, Jan 8, 2015.
  1. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    I still haven't found my feeler gauges and gaping tool.
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I recommend the wire type gauges, usually round with several measuring wires. I forgot the reason I was told its preferred but many years ago a Jag mechanic taught me to use one.
  3. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Surprisingly, the original tool really is about the best tool for the job ---- if you get creative, many other things will work, but I always prefer using the OE tool.
  4. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    I have (had?) one of those but worry that pulling it through a tight gap repeatedly they'll deform over time. I suspect that given the individualities of these cars spot on spec. doesn't necessarily yield optimum results.
  5. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    Given the signs of use on mine it wasn't used just once. So it can't be that bad.
  6. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
  7. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,555
    Scottsdale AZ
    Stu Boogie
    NGK BPR5ES. $2 and in stock at your local O'riellys. Change once a year they will be fine.
    Also if you are changing plugs... It's a great time to run a compression test. I do it cold but some like it hot:)
    Threading the rubber compression hose on the back bank, now that is a really good time!
  8. jsumnertx
    jsumnertx Karting
    Dec 9, 2004
    165
    Austin
    Sean and Mule's posts reference a 5/8inch socket. NGK BPR5ES plugs take a 13/16ths socket. Is 5/8ths for a different plug?
  9. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,086
    FRANCE
    Mule's car is a 328; the 3,2 engine has smaller-diameter spark plugs than the 3,0 litre, 12 mm versus 14 mm; this might explain that?
    Rgds
  10. Steve Magnusson
    27,022
    The numbers got a little mangled in this thread, but neofer has the concept:
    The 14mm thread F engine spark plugs (e.g., 3.0L) use a 13/16" hex drive
    The 12mm thread F engine spark plugs (e.g., 3.2L) use an 18mm hex drive
    There are some 14mm thread spark plugs that use a 5/8" hex drive, but these tend to be the gasketless tapered seat kind of spark plugs (had a couple of Ford 351 Cleveland that used them).
    Portofino likes this.
  11. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    I posted that link as an example picture of the tool I have. The one I have fits my plugs, but I can't tell you off hand the exact size. My last major service says spark plug is part number 131927.
  12. jsumnertx
    jsumnertx Karting
    Dec 9, 2004
    165
    Austin
    For reference and posterity
    For my 1979 308 GTS North America
    Oddly, the CT-407 worked in cylinders 1, 2,4 but not cyl 3. That tube was slightly narrower. Has anyone else noticed that specific tube being narrower or is something else going on?
    The Briggs and Stratton wrench is narrower but it's too long for cyl 3 unless I undo the torque bar connected to the valve cover
  13. Mike Haring
    Mike Haring Rookie
    Aug 30, 2018
    6
    Mike Haring
    I have sourced a number of older Craftsman sockets that are thin (walled) enough!!
  14. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,931
    Mike 996
    "Change once a year they will be fine."
    Since a spark plug doesn't deteriorate with time, I'd use mileage as the replacement guide. The 328 owners manual says 30,000 miles. For most owners that probably means that when you change the plugs the first time, it's also the last time. ;)
