Spark plug wire holders | FerrariChat
Discussion in '308/328' started by chasjen, Apr 12, 2024.
  1. chasjen
    chasjen Karting Silver Subscribed
    Oct 21, 2013
    81
    Dublin, Ohio
    Charlie
    Need advice. Is there a trick or easy way to remove remnants of broke spark plug wire holder stud from the cam covers? Thanks. Charlie
  2. Rifledriver
    37,105
    The hole in the valve cover is threaded. If any is sticking out grab it and spin it out.
    If not, drill a small hole in the center and stick a small sheet metal screw in there and pull out the center pin then use a small screw driver to grab the outer shell and spin it out.
    smg2 likes this.
  3. chasjen
    Oct 21, 2013
    81
    Dublin, Ohio
    Charlie
    Thank you.
  4. smg2
    smg2 F1 World Champ Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    For reference the thread pitch is m7x1. The plastic inserts use a center push in to expand the outer sleeve into the threads.
  5. chasjen
    Oct 21, 2013
    81
    Dublin, Ohio
    Charlie
    Perfect. Worked like a charm. Thanks again.
