spark plug wires | FerrariChat
spark plug wires
Discussion in '308/328' started by ragtop1, Sep 12, 2015.
  1. ragtop1
    ragtop1 F1 Veteran
    5,258
    Ontario
    Larry Warren
    I'm replacing the spark plug wires and can't source out 7mm diameter at the local shops. Do 8mm wires fit in the distributor cap holes ?
    thanks
  2. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Not without some careful trimming, but it can be done.
    7mm is available, but you're right that you won't be finding it Autozone and Pep Boys. Magnecor I think is where I'd start.
  3. ragtop1
    ragtop1 F1 Veteran
    5,258
    Ontario
    Larry Warren
    #3 ragtop1, Sep 12, 2015
  4. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    8MM fit in mine without having to trim them.
  5. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    On my '82 308i the wires are pertronix 7mm - 500 ohm/ft.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,677
    San Carlos, CA
    Mitchell Le
    Kingsborn sells them in 25 ft rolls.
  7. ragtop1
    ragtop1 F1 Veteran
    5,258
    Ontario
    Larry Warren
    Thanks for the replies gentlemen, I like the idea of buying a roll and making my own. 25' sounds about the right length. Good idea yelcab
  8. Jdubbya
    Jdubbya The $10 Trillion Man
    43,742
    Hell's waiting room
    Just be sure to use the correct type. For stock ignition copper core is fine. If you have upgraded ignition like Pertronix or a direct fire system you want wire wound resistor wires. Using the old style copper wires with a newer electronic igniton can interfere with proper operation.
  9. Jdubbya
    43,742
    Hell's waiting room
    And I put Taylor 8mm wires into repro caps on mine. i used a large drill bit BY HAND to gently chamfer/ease the edge of each hole. I also cut the end of the wire down to the core and folded the core back on itself. Was advised to do this by an old timer. It does give you a better chance of making sure you hit the core solidly with the brass pin.
