Spark Plugs Question for QV | FerrariChat
Discussion in '308/328' started by miketuason, May 12, 2018.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,806
    Cerritos, CA.
    Image Unavailable, Please Login Time to replace my spark plugs as I t has been eight years, this is what I have been using and seems to work for the past eight yrs until it starting to miss fire when it’s cold. Question is, should I use the same plugs or is there a better one for the QV, and also what is the proper gap for my 84? Last I didn’t set as I was told the gap are preset already.
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Those are exactly the plugs I installed nearly a year ago, and they've been running great.
    You can gap those plugs, contrary to popular belief, but often you don't need to. If you choose to do so, you must be extremely careful not to put any pressure on the iridium tip.
    Offhand, I cannot remember the factory gap for the older style plugs. The torque procedure is to tighten to 18 lbs, then back off (loosen it), then torque the final to 14 lbs.
  3. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    The Q.V. gap is .24-.28 range so it is worth checking that your iridium aren’t preset more in 30-50 bracket.
    If they’ve been in for 8 years, what deteriation have you seen? I assume they, and the wires, have been inspected and the car runs good.
    As long as they meet the OEM heat resistance of N6 GY they will be fine. My notes say torque 18, then back off to 14. At about a fraction of the price you might find the champions run fine and you can change at will:)
    Post a pic of what comes out - consider keeping them (labelled) and swap out next for comparison.
  4. miketuason
    Feb 24, 2006
    15,806
    Cerritos, CA.
    Thanks Stu! I will post what the old plugs looks later as I haven’t pulled them out yet. Extenders and wire seem the in good condition as far as I can see. Thanks for the gap and torque spec.
  5. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Your welcome, for ref, the current champion replacement is: Plug Type RN8WYPB3; Gap .028. Price point no doubt moved north!!!
    Thorn, apologies, I missed that you’d included the torque specs!
  6. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    No worries, I was glad to see you list the gap specs I couldn't remember. :)
    StuR likes this.
  7. miketuason
    Feb 24, 2006
    15,806
    Cerritos, CA.
    I always thought Iridium are best suited for carbs car as carbs are more likely to foul plugs but I used them on my QV anyway.
  8. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Yeah the champion plug recommended is an iridium. Oddly they recommend double copper for the 3.2 /86.
    What is also important is whether your new plugs need anti-seize. Whilst the originals needed it to prevent head damage, some new plugs have revised metal content that prevents seizure and do not work well with a-s as it prevents heat dissipation.
  9. miketuason
    Feb 24, 2006
    15,806
    Cerritos, CA.
    Is there a big difference between NGK Iridium plugs and Champion Iridium plugs?
  10. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Probably only price point when it comes to our engines. I have used both. My last set were champion, just got a good price.
  11. miketuason
    Feb 24, 2006
    15,806
    Cerritos, CA.
    #11 miketuason, May 15, 2018
    I just ordered the new NGK Laser Iridium plugs which are supposed to be better and specked to last 100k miles. The cross reference number of the regular Iridium of BPR7EIX to the Laser Iridium is IFR7L11 (Stock# 5114) After my online search, I found Summit has the cheapest price.
  12. Sean308
    Sean308 Formula Junior
    Jan 12, 2011
    287
    Victoria, Australia
    Sean
    Whats your technique when taking off the spark plug boots? I have new spark plugs but have not had a chance to change them yet, but read a few posts about taking care when removing boots, any recommendations?
  13. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Never had a boot problem, just a pull to remove. On the mondial, the front bank is a bit of a stretch so I assume so for the 308. Not sure if you need :benefit from removing the lid. But I would put a towel/blanket over the side of the car and don’t wear trousers with rivets or a belt buckle - sounds silly, but easy to scratch when reaching over. A small step helps too (but I’m only 172 tall).
    Check your wires when they’re off and look for any cracks on the boots etc. Sure they’ll be fine. Lots of threads here about renovating/replacing cables without the Ftax!
  14. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,870
    Mike 996
    When replacing, put some silicone grease (sometimes referred to as di-electric grease) in each boot. It will make subsequent removal much easier and also protects against moisture/corrosion. For that matter, use it on every electrical connection from battery terminals to the various plugs/connectors.
  15. miketuason
    Feb 24, 2006
    15,806
    Cerritos, CA.
    Also beside checking the plug wires, inspect the extenders as well for pitted marks and burnt holes, I’ve heard this thing commonly happen. As for pulling the wire off, I usually I spray a little wd-40 on the black clips that holds the wire together and slide them off carefully before pulling the wires off the plugs, if they’re stuck, you can break the clips.
    StuR likes this.
  16. miketuason
    Feb 24, 2006
    15,806
    Cerritos, CA.
    Image Unavailable, Please Login Update: finally I just received my Laser Iridium from NGK as the first set they sent was wrong but got it right this time. Anyway a few difference, the new Laser Iridium still has the 14mm thread size but it is now has the smaller hex which is actually better now as, instead of using the big 13/16 spark plug socket, it now require to use the smaller 5/8 (16mm) socket. The pic show that the Laser Iridium has a much sharper Center electrode almost like needle type compare to the regular Iridium type(left) that came out of my QV.
