Spark Plugs - Use caution when washing your car! | FerrariChat
Discussion in '348/355' started by ferrariwant2be, May 28, 2008.
  1. ferrariwant2be
    ferrariwant2be Karting
    Jan 14, 2008
    87
    #1 ferrariwant2be, May 28, 2008
    Before I purchased my 355 I discussed some basics with the mechanic among which he brought up the subject of washing it. He said not to use a pressure washer - at least not near the engine when it's hot. Water will get into the plug galley. If the plug is HOT it will crack the ceramic and cause the spark to ground on the plug jacket and not on the ground electrode. This will effect idle quality and power output.
    He cut away the jacket from another plug he obtained from another Ferrari to show me. I don't know if the plug was out of a 355 but it was very similar - perhaps only differing by a heat grade. I don't have it anymore so I can't double check. ANYWAY, I took a picture of it next to one of my old rusty plugs for all to see. Apparently the previous owner got water in there but I don't know if any of mine were cracked. It ran quite a bit better at idle when the plugs were changed though. I will be careful when washing.
  2. f355spider
    f355spider F1 World Champ
    18,053
    Smart Ferrari tech. I had a couple rusty plugs too, a few years ago. Mainly because the foam blocks were not installed during the previous major service! These blocks are located at the rear most part of the valve covers, wear the plug wires exit the valve covers. So with no blocks, the most rearward plug on each bank got a little wet over the years (I have never used a pressure washer, but normal washing or driving in the rain must have allowed some moisture in without the proper foam blocks. In addition to the foam blocks, you also need to make sure you have the proper gaskets on the valve covers that seal the covers after replacing the spark plugs.
  3. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    +1, rusty plugs here too. None cracked and I don't think engine performance was affected, but still not a good thing. Personally I'd never wash the engine cover with water, just dust it with a Cali Car duster.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Likewise on the California Duster.
    Most times a wipedown with "Quik Detailer" is all you need even if the car looks dirty. I would rarely recommend washing with water unless you really like wet feet, drive on a lot of dirt roads or are parking outside under a tree that drips.
    Generally among Ferrari owners I see too much washing, not enough driving. ;)
  5. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    How many owners just do a sponge wash (no running water over the surface)? That's what I've always done, but after reading tropicaldetail's excellent wash, care, and detailing posts, I understand more water=fewer paint swirls. Water helps flush grit away from where you're working. He also says car dusters = more swirls, since they just hold and rub the grit over the surface. So after I get my paint spruced up, I'm going to rethink my wash methods.
  6. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
    I always wash with water, my car gets far to dirty from being used every week, much to dirty for quick detailers. I always follow the instructions posted by Todd (tropical detail); the 2 bucket method is a great way to keep as many scratches off the car as possible.
    I have not checked my plugs since my major 8 months ago, might take a look at my annual just to make sure all is well. Thanks for the heads up. :)
  7. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    RAIN???????? These cars will not melt???
    :D
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I've seen cars with serious rust that have never been in a rain.
    I repeat, less washing, more driving.
