Spark Plugs | FerrariChat
Spark Plugs
Discussion in '348/355' started by fxdwgs, Jun 29, 2007.
  1. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    Just fitted a set of new spark plugs. Bosch Silver something. No jap crap here
    only high quality from "das Vaterland".
    By the way, bought some floor mats from Greg also. Special price and all that but they look nice. Especially since everything indoors is black these mats sort of lits it all up.
    Will take some photos for you guys when the battery to the camera is charged.
    You won´t get disappointed they look real nice in there.
    //B//
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Bosch plugs with 4 ground posts or 1 ground post?
  3. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    Do not know what you mean.
    Can you show?
    //B//
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #4 No Doubt, Jun 29, 2007
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    If one is good more is better??? ;)
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yes. Primarily because the fire from the spark isn't shielded by the ground.
    Look at the single ground spark plug above. Now picture the spark between the ground and the power. Notice how that spark is somewhat shielded by the single ground such that its light will cast a shadow over the center of the piston.
    The 2 ground and and the 4 ground plugs (even the split ground on the competing Splitfire plugs) don't cast a shadow when the spark fires...as the center is open so that the flame isn't shielded.
    Also, multiple grounds allow the spark to naturally choose the path of least resistance, which keeps a good spark for more miles as the ground electrode wears and as carbon buildups acrue.
    In turn, that lower resistance over time (compared to a single ground plug) means lower amperage increases to get the required spark.
  7. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    Got your point from the photo you showed. Just bought some similar to what wa already there. Had NGK before but wanted something better so I checked the Bosch homepage and they recommended these sparkplugs. I can get you the partnumber if you want. It was Bosch silver something. Which actually means the + pin is a thin silver wire.
    Still owe you the photos from the floor mats, but i have been away for a few days. Went for a boat trip with a steamer from 1910. The engine was the original one from 1910 working with steam 2 cyl but converted from charcoal to diesel.
    She made 10 knots. I can show you a film of the engine running but do not know how to put such a thread in here.
    //B//
  8. f355spider
    f355spider F1 World Champ
    18,053
    Like multiple blade razors, do you not expect to see 8 prong sparkplugs in our future?
  9. 355
    355 F1 Rookie
    3,643
    Toronto
    Frank
    While we are on spark plugs. Who makes the best wires out there for the 355? And of course they have to fit in that little thing a ma jig that fills the hole to bring them under the cover.
  10. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    They only need to be 7mm to fit into "that little thing a ma jig" ;). I used kingsborne. :)
  11. f355spider
    18,053
    Kingsborne here too...but get the 7mm, I have the 8mm and it was a pain to get through that foam plug on the end of the cam cover. The Kingsborne are basically identical to the factory wires as they use oem Beru connectors on each end. Just tell them to use 7mm wire, and you are good to go.
  12. 355
    355 F1 Rookie
    3,643
    Toronto
    Frank
    Thank you guys.
  13. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I used 8mm too... I used a different seal/ method. ;)
    Anytime!!! 355s rule!!! :D
