Spark Plugs | FerrariChat
Spark Plugs
Discussion in '612/599' started by MASR04, Aug 25, 2015.
  1. MASR04
    MASR04 Formula 3
    Feb 20, 2013
    1,505
    Eastern NC
    Sean
    In order to change plugs - I'd have to remove the two air intake hoses and the plastic pieces in order to access the ones in the rear?
    NGK is like $14 a piece
    AutoLite is $3 Ferrari only recommends NKG - what difference would it make if I decided to do this every 12 mos vs. every 3 years...
    Thanks in advance. I am not always looking to go cheap. I know enough to know that Spark Plugs are Spark Plugs - ESPECIALLY IF REPLACED REGULARLY..
  2. Cribbj
    Cribbj Formula 3
    I don't believe all spark plugs are created equal :)
    They are, however another of those "religious" topics like oils. Myself, I wouldn't put Autolites or Champions in my lawnmower, and I've had plugs from both Mfg's leak past the ceramic, and have even had the upper body separate from the lower.
    Nothing but NGK's or Denso's for me.
    PAP 348, George Vosburgh and Makuono like this.
  3. MASR04
    MASR04 Formula 3
    Feb 20, 2013
    1,505
    Eastern NC
    Sean
    Thanks for the advice. Will take it to heart.
  4. Roupin
    Roupin Formula 3
    Oct 7, 2013
    2,167
    Encino
    Roupin
    You want to install inferior spark plugs and then replace them annually?
    With your math you will only save $20 per year...and be burdened with the 3x the labor.
  5. MASR04
    MASR04 Formula 3
    Feb 20, 2013
    1,505
    Eastern NC
    Sean
    Never claimed to be intelligent. Just diligent in doing research!
    Still at the stage where I have more time than Money.
  6. Andrew McCrae
    Andrew McCrae Formula Junior
    Jun 5, 2016
    250
    Ireland
    Interesting as the Fiat Dino original plugs were Champion N70Y
  7. brogenville
    brogenville Formula 3
    2,217
    Robin
    My first thought is that this seems like something you don’t want to admit to on a car forum. At least not on a Ferrari forum.
    Beyond that, I believe your procedure is basically correct.
  8. tazandjan
    39,032
    I replaced the Champions in my Fiat Dino with NGKs and did the same thing with the Dino 246 GT and 365 GTB/4. The wide heat range NGKs were the best thing ever for old Ferrari engines, which used to foul other plugs regularly.
    Sean- I would not put anything but NGKs in a Ferrari and have been using them for 45 years.
  9. IcemanWlkp
    IcemanWlkp Karting
    Oct 15, 2020
    50
    Marek Orli
    The service uses NGK PMR8B spark plugs, catalog number 6378. These are platinum spark plugs, or does NGK also produce iridium spark plugs for 599 and are they better?
  10. tazandjan
    39,032
    Not for the 599. I have them in my 575M, but they did not make them for the next generation 2 seat GT or any F140 engine.
    Skidkid and George Vosburgh like this.
  11. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    +599
    Stick with NGK plugs for every petrol engine, from your lawn mower to your Ferrari! NGK spark plugs are the best! :D:D
  12. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    There was a time (a few decades ago) when Champion plugs were the hot ticket in virtually all cars. You'll find them listed as OEM in Ferraris & Lamborghinis. In the age of carburetors and breaker point ignition, it was common to change plugs pretty often.
    Those days are in the past.
    Today, fuel injection, electronic ignition and some significant improvements in spark plug technology, keep plugs a lot cleaner. It's not unusual (or recommended) for cars to have 100K miles on the same plugs.
    NGK and Bosch, make good products. Champion is an obsolete brand.
    Replace them when necessary.
  13. tazandjan
    39,032
    I remember when Bosch first came out with platinum plugs on my 69 911S. Made a world of difference in limiting fouling. The NGKs, however, were even better. I tried some gold Champions once on my 911, but quickly went back to the Bosch platinums. NGKs were not well known that long ago, but by 1975 they were all I would use in my Ferraris.
