Spark Pug Check | FerrariChat
Spark Pug Check
Discussion in '308/328' started by wda24729, Mar 10, 2016.
  1. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Carried out a search but couldn't find the info.
    I want to use NGK Iridiums. The plugs I have at the moment are NGK BP7ES and the equivalents show as BPR7EIX however whenever I do a search for these it states that are not compatible with my model
    Car is 1980 308 GTSi 2V.
  2. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,834
    Cerritos, CA.
    Not sure about on the two valves but BPR7EIX is what I use on my QV. I think as long as you match the original heat range for the Iridium, it should be ok.
  3. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,949
    Says who? If you go to the NGK website (www.ngksparkplugs.com) and look up your car in the application guide, it specifically lists BPR7EIX (and BPR7ES) as being correct for your model (BP7ES is a non-resistor type plug that is A-OK to use on your model, but spark plug manufacturers have gone to typically only making resistor type plugs in modern times).
  4. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    On my 82 2v. I use BP6ES. The extenders are 0 ohm and the wires are about 500/ohm/ft. I have also use 7s
  5. Rifledriver
    37,288
    Generally speaking a 6 is better suited to a carbureted car and a 7 to an injected car.
  6. are-jay-bee
    are-jay-bee Rookie
    Sep 11, 2012
    23
    Surrey, England
    Robert Bruce
    I use NGK BPR7EIX in my UK 1978 2v dry sump carb GTB, they're excellent.
    If you use Amazon, Ebay or car shop compatibility check they will never veer from original spec, probably Champion N7Y, so will never say any NGK plug is okay.
  7. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Thanks - BPR7EIX it is then.
  8. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    What was the original Champion plugs recommended for a 1985 308 QV? I would like to have a set so I can add it to my Toolkit.
  9. Rifledriver
    37,288
    Probably better to ask in the tool kit thread.
  10. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    Champion N6GY
  11. Fitz
    Fitz Karting
    Jan 27, 2004
    88
    Amelia Island
    Frank
    I use the BPR7EIX in my 79 carb GTB and they run well with good color no fowling.
  12. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,071
    Anybody else notice inductive pickup devices like tachs & timing lights work appreciably better without resistor plugs? I have several inductive devices that were really flaky, or flat-out wouldn't function right with resistor plugs & resistor wires & resistor plug extenders.
  13. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Is there anywhere to get some Champion N 6 GY plugs? They dont seem to be available anywhere...>
