Special OBD11 codes | FerrariChat
Special OBD11 codes
Discussion in '360/430' started by Ingpr, Feb 7, 2011.
  1. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Can anyone tell me what are these codes,
    P1324
    P1124
    P0455
  2. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    David,
    Here are some details about your codes :
    P1324 RH STAGE SENSOR : Minimum threshold exceeded - The timing sensor signal is too delayed with respect to the engine rpm signal - Check : Signal panel check. Timing variator check. Engine Timing Check
    P0455 ANTI-EVAPORATION CONTROL SYSTEM : Minor leakage - Incorrect pressure increase within the fuel tank.(Minor leakage) The error can be validated only while running the anti-evaporation test. - Check : Using the Tester, run the leakage diagnosis cycle and check the result. Check that the parameters read are consistent with all the circuit lines and with the system components. Wiring / component intactness check.
    P1124 ???
    Hope this helps,
    Stef
  3. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Thanks Stef!
  4. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,454
    1124 long term fuel trim addaptive air system too lean.
  5. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Likely a busted pipe on the evap system, broken on top of the tank. Resulting air leak has caused big fuel adaptive issue on the affected bank, causing cel
  6. sailingmagnus
    sailingmagnus Rookie
    Nov 20, 2010
    31
    Satellite Beach, FL
    Scott
    Rustybits, you make a statement "Likely a busted pipe on the evap system, broken on top of the tank. Resulting air leak", that I have been trying to track down more details on. I too get a P0455 CEL code from time to time. By searching the forums I have seen there was a service campaign to replace the rollover check valves on the fuel tanks but I still believe people are having problems and I am looking for more details why.
    My Ferrari dealer did a smoke test on my 2001 360 and showed me there was a leak coming from the top of my driverside tank area. Being a Spider they wanted $1500 in labor to remove the top and another $1000 in parts to replace the check valves. I have been searching the forums for details on how to remove the top but can't find any. One thread shows the top being removed via a special lift....but I'm thinking a chain host and rope attached to the rollbar should be able to lift the top assembly easily once unbolted from the car.
    What's the most common "busted pipe"? I understand some plastics become brittle with age but is it the plastic pipe that is busting or is it the rubber tank seals that leak? Has anyone detailed the steps to remove the rollbar/top assembly?
