Special Tools | Page 2 | FerrariChat
Special Tools
Discussion in '206/246' started by omgjon, Jan 10, 2015.
  1. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #26 synchro, Jan 13, 2015
    Great thread OMGJon! What do others use for installing their seats?
    Cut down a 6mm allen wrench to access the front seat mounting bolts. It is slow going but once the fronts are in then slide forward so a ratchet can be used for the rears.
    Hint: might need a wobble, universal or eccentric for easiest method.
    Your solution is superb and evenly controls the pressure applied to the gauge trim ring.
    I see you have two dies for the different size of Dino instruments - wow!
  2. abstamaria
    abstamaria F1 Rookie
    Feb 11, 2006
    2,668
    Andres
    Champtc, how long is that tunbuckle? A great idea.
    Andres
  3. omgjon
    omgjon F1 Rookie
    3,574
    Spicewood, Texas
    Jon Gunderson
    #28 omgjon, Feb 11, 2015
    I made this jig to cut and glue the rubber for the vent glass for the GTS models. The Gt rubber comes in one piece with no cutting or gluing required.
  4. tx246
    tx246 F1 Veteran
    6,705
    Texas
    Shawn
    Does the GTS form have to be completely hand made?
    Such a dumb question, but I hadn't heard that before.
    Shawn
  5. omgjon
    omgjon F1 Rookie
    3,574
    Spicewood, Texas
    Jon Gunderson
    The upright piece is cut and fitted and a separate piece. The other 2 sides are about an inch or so too long and have to be trimmed and fitted.
  6. tx246
    tx246 F1 Veteran
    6,705
    Texas
    Shawn
    That is pretty crazy and annoying. I had no idea that the current pieces offers were that far off.
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Bicycle wrench ?
  8. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #33 synchro, Nov 8, 2015
    pic
  9. dgt
    dgt Formula 3
    Jan 14, 2011
    1,293
    Northeast, USA & Oz
    Andrew
    #34 dgt, Feb 10, 2016
  10. swift53
    swift53 F1 Veteran
    8,619
    E.S.
    Alberto
    Andrew, is it possible to make two sets?
    Possibly it might lower the cost of the 'Bleriot Bros.' assembly.
    Regards, Alberto
  11. pshoejberg
    pshoejberg Formula 3
    1,884
    Denmark
    Peter H
    Make it 2 1/2 sets....I am missing my lhs chrome edge.....You got my full respect for that jig Andrew....fantastic.
    Regards
    Peter
  12. dgt
    dgt Formula 3
    Jan 14, 2011
    1,293
    Northeast, USA & Oz
    Andrew
    Thanks guys, this was the second jig we made. The first set didn't work out, much time and money spent!
    I spoke to Alberto on the phone about this, it's very labor intensive to make these trims and they need to be fitted to the car before final chrome.
    The trim varies from car to car and even side to side, handcrafted.
    I'll see what I can do....
  13. pshoejberg
    1,884
    Denmark
    Peter H
    #38 pshoejberg, Feb 16, 2016
    Much Inspired by Andrew I decided to make my own chrome list. Bought some standard brass profiles and soldered them together. Spent an hour at in the rollers to shape the sandwich and a few more hours with my angle grinder, hand files and sand paper. The result is actually quite good and much nicer than the piece of useless stainless steel crap I spent more than 400$ on. Of to polishing and chrome. One less part to source...
    Regards Peter
  14. swift53
    swift53 F1 Veteran
    8,619
    E.S.
    Alberto
    #39 swift53, Feb 2, 2024
    https://www.amazon.com/URREA-U3532M-32mm-Service-Wrench/dp/B00I6A6KNW/ref=sr_1_6?keywords=32mm+aluminum+wrench&qid=1706919203&sr=8-6&th=1
    URREA Service Wrench - 32mm Mechanics Wrench with Thin Forged Design & Satin Finish - U3532M
    Much cheaper than an ally hydraulic fitting wrench, plus no grinding...
    Regards, Alberto
