Speciale water temperature - how hot is too hot? | FerrariChat
Discussion in '458 Italia/488/F8' started by 720, Jun 25, 2015.
  1. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    So. Cal and No. Utah
    Rick
    I apologize in advance if this is common knowledge, but I don't know the answer. I searched the owner's manual and I couldn't find what I was looking for.
    It was hot today about 98 degrees F, and I was driving fairly hard through the mountains. I noticed my water temperature was about 210 - 215 F. I'm curious if this is "normal" and how hot is too hot?
    I checked the radiator and the coolant level was full. I could hear the radiator fans running when I stopped.
    Thank you.
  2. rockitman
    rockitman F1 Veteran
    May 31, 2015
    5,989
    Upstate, NY
    Christian
    That is fine. Cars run hotter these days for emission reasons. My old 2004 Porsche GT3 would hang at 180 degrees F...My recent 2015 GT3 ran up to 215-220 F.
  3. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    Thank you. Glad to know 215 degrees is not excessive.
  4. ONEOFEW
    ONEOFEW Formula Junior
    Jan 19, 2006
    835
    LA
    Steve
    My 13 spider on a 110F day through the canyons aggressive driving reached ted under 210, even on stop n go situations never pegged 210, fans come in around 195 bring it down to 185.
    I honestly can't comment on the Speciale, it's possibly a hotter running car, but I think 215 is a little high. When the fans came on did it drop?
  5. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    I couldn't hear the fans while driving so I don't know when they were on or off. When I came to a stop I could hear the fans. While driving the temperature seemed to move between 210 and 215.
  6. ONEOFEW
    Jan 19, 2006
    835
    LA
    Steve
    Honestly I don't know how Speciales run, maybe someone else will chime in, but as a rule of thumb, if you pull over and the fans are able to bring the coolant temp down to 185, it's doing it's job.
  7. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    I'll go for another run tomorrow, and I'll watch the temperature more closely. How quickly would you expect the fans to cool things down to 185 from 215?
  8. ONEOFEW
    Jan 19, 2006
    835
    LA
    Steve
    prob 3-4min at idle, temps drop n the fans stop. Also see where your oil temp is when you're running at 210-215.
  9. RC33
    RC33 Formula Junior
    Nov 29, 2005
    836
    Garden City
    RC33
    A recent track day with ambient temperature of 39C (102F), the water temps reached a peak of 102C (215F) and Oil temps are higher at 106C (223F) consistently whilst pushing its limits lap after lap but both subsequently cooled down to 90C (194F) during the cool down lap for brakes and engine before entering pits.
    Numbers were taken from an AIM SOLO DL meter receiving all data from the ECU via the OBDII port.
  10. justthebest
    justthebest Formula Junior
    May 14, 2014
    319
    Denver, CO
    Most gas vehicles nowadays will top out around 235-45 before they go into limp mode or similar. If you see that, start to worry.
  11. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,664
    South East
    Jimmie
    There's a red line on the gauge which I think begins at 250 deg - isn't that a clue ?
    And that's without looking out for the overheat idiot light
  12. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    When you look at the engine data, you will see the advance start backing off (advance) at around 105C, and gradually continue to back off until around 115C and plummets from there. The ECU map uses water temp, oil temp and ambient air temp among other variables. You'll get all sorts of warnings by then.
    Running hard on a "hot" day (85-90F ambient) my engine tends to sit at 95C and oil around 99
    So, to some degree (pun intended), engines run weaker in hot conditions to start with, the Ferraris back themselves down noticeably when they are out of the optimum window.
    One "maintenance item" people can consider if tracking is to make sure the radiator and various oil coolers are blown out and cleaned. Changing radiators is an annual maintenance item on the Challenge cars - won't kill you if you don't, but it helps with cooling efficiency.
  13. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    Are you trying to answer my question, or are you just being a jackass?
  14. greyboxer
    Dec 8, 2004
    12,664
    South East
    Jimmie
    I'm pointing out that there are two obvious systems to tell you your car is not too hot
  15. FerrariFL
    FerrariFL Formula Junior
    Dec 2, 2012
    526
    I was just about to posit the same question and found this thread... My water temps after stop and go traffic in 100 degree weather today were btw 210-215. When I started driving, as expected cooled down. I kind of remember this from driving last summer. Can anyone comment if they have experienced the same?
  16. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Dealer says not to worry until the needle gets into the red.
  17. ONEOFEW
    Jan 19, 2006
    835
    LA
    Steve
    Speciales seem to be running higher coolant temps than the 458, I noticed mine gets up to 210 in stop n go traffic as well.
  18. dmark1
    dmark1 F1 World Champ
    BANNED Owner
    Feb 26, 2008
    11,439
    Americas Team Headquarters
    Mark
    210 is as high as mine gets and thats in Dallas 105 degree temperatures.
  19. FerrariFL
    Dec 2, 2012
    526
    Mine goes on tiny click over 210 for a little... Not quite to the next bar. It was close to 105 on the black asphalt today.
  20. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    My Speciale runs at 210-220F when it's hot outside say 100F in the mountains around 7,500 to 8,500 feet. But when I'm at the beach on a hot day my water temperature runs lower 190-200F (probably because no elevation changes at the beach).
    Also, my butt dyno estimates I'm down at least 100HP in the mountains. When I go back to the beach that extra 100+ HP really makes the hair stand up on the back of my neck. LOL
  21. 458trofeo
    458trofeo F1 Rookie
    Feb 4, 2013
    4,426
    City of Angels
    101 aki
    Imho the temps Rick is reporting are normal: if the ext. temp is warm
    and that you are running through twisty canyons roads, as opposed to straighter
    roads like freeways or tracks, it means that not so much air is flowing through
    the car and that engine is more often than not in the high rev range if one is
    driving spiritedly, which make H2O temps high.
    Fwiw when H2O temps get too high I back off running the engine hard and they get
    back to normal, btw I always run 100% 100-101aki fuel so mine gets hot too :D
    Don't worry all is normal: enjoy the car! :)
    xoxoxo
  22. 458trofeo
    458trofeo F1 Rookie
    Feb 4, 2013
    4,426
    City of Angels
    101 aki
    #22 458trofeo, Aug 6, 2016
    Rick,
    Fwiw I just checked: I let my Italia with 100-101aki run
    215F H2O temp at its hottest, usually if I see her going over 215F
    I take it easy and let her cool off to about 190-195F; on the fwy
    with no traffic and steady stream of high speed air she gets down to
    175F but usually hovers around 180F.
    All in all I would say that her average operating temp is 190F - 200F
    so I would not worry about seeing the slightly higher temps under the
    conditions you mentioned.
    Fyi my car's fans kick in at about 200F; the others scream ecstatically as
    they hear me drive by :D
    best
  23. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    #23 720, Aug 6, 2016
  24. 458trofeo
    458trofeo F1 Rookie
    Feb 4, 2013
    4,426
    City of Angels
    101 aki
    Cool! ;) Did you get the 4WD option? :)
  25. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    Rick
    My Speciale runs hotter (about 10F+) at high altitudes (7,000-8,000 feet) than it does at sea level even when the outside ambient air temperature is the same (let's say 90F).
    I've been looking around for an explanation. There seems to be several things that come into play, but there's one thing in particular that caught my eye.
    I've summarized a bit of what I found:
    Hotter ambient air temps and higher altitudes result in less RAM air pressure, and this in turn results in less volume flow through the radiator. At 6,000 ft, for example, the pressure is reduced by about 20% from its sea level value.
    In addition, RAM air pressure is proportional to MPH^2. I think this means that at 35 MPH the RAM air pressure is reduced X4 from what it would be at 70 MPH. This seems significant. It might explain why my Speciale runs so much hotter around town at altitude than it does when I'm driving around Laguna Beach.
    If I'm understanding all of this correctly, it seems that the radiators on cars (or so it seems) may have been optimized for sea level and not high altitudes.
    Do you think this would explain why my Speciale runs about 10F hotter at altitude compared to sea level? Maybe someone with a technical background can shed some light on this subject??
