Speed Bleeder size for 348 | FerrariChat
Discussion in '348/355' started by dahveedem, Mar 26, 2014.
  1. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    so I did a search of the forums and found references to speed bleeders (some of my own) but can't seem to find the size of the thread for 348 calipers.
    Anyone know it?
    Here's link to SB site for sizing.
    Speed Bleeder Sizes
    Thanks in advance.
    David
  2. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    #2 348Jeff, Mar 26, 2014
  3. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    That's the bleeder right?
    That is awesome.
    Thanks! !!
    Mobilized reply by Dahveedem
  4. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    #4 348Jeff, Mar 27, 2014
  5. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Thanks for the bleeder shots.
    Here's the other question...
    It appears there are 2 versions of calipers.. Teves and Brembo. Thoughts on how to tell the difference?
    Checked with Ricambi --- while they have the OEM bleeders they don't know the sizing.
  6. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    #6 348Jeff, Mar 27, 2014
  7. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Thanks.. I'm assuming the pitch is 1.0 on these as well?
  8. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    Should be - if you look at my pic further up Ive swapped the brake hose into the bleeder hole and the bleeder into the brake hole so they are the same
  9. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    #9 348Jeff, Mar 27, 2014
    Just thinking...buy 5 rather than 4 and fit one to your clutch bleeder on the bell housing.
    NB you should always bleed your clutch after bleeding brakes as they share the same fluid reservoir so it would be a shame to speed bleed your calipers only to have to revert to doing the final one the old way.
    As a guess its the same size
  10. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Thanks for the tip... bleeding clutch the same process as the brakes?
    turn key to activate abs pump and then pump the clutch?
    i'll have to pull a wheel and see what caliper I have on the car.
  11. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    As far as I know you dont need to to have the ABS activated for clutch bleeding - that's just the brakes.
    If you look at the bottom of this thread covering when I replaced the throwout bearing it shows how I did it.
    Clutch Slave Cylinder Release/Throwout Bearing Replacement incl. Triple Seals
    BTW ou dont need to remove a wheel to see the caliper markings - you can see it from the back of the car if you use a torch
  12. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Sweet!
    Thanks!
  13. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Speed bleeder SB1010S M10 x 1.0 confirmed for the Brembos for my '93 348 TS serie speciale. Now for 6 more! Then some beautiful super blue racing DOT4 fluid.
  14. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    Excellent :)
    These will be the sam for the ATE as well then as there is no difference in the Ferrari parts catalogue for bleeders between years and calipers.
    If you could pop up a couple of pics of them for interest that would be great. :)
  15. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Will do... btw... The clutch bleeder... waaay bigger. At least on mine. Will need to figure out that size.
  16. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    Woops I am so daft - yes of course they are different - DOH!
    Just looked at my post above which said buy 5 rather than 4 - shoud read buy 8 then a clutch one too - how daft am I?! sorry!
  17. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Any idea what size? It's kinda big. Not sure a speed bleeder mashes one big enough
  18. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    Ill have a look in the morning and see if I can find my old rusty one and measure it.
  19. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    I'd pull mine out but I'm afraid how much it will leak. ..I'd guess a 12 mm or maybe 14mm
  20. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,667
    San Carlos, CA
    Mitchell Le
  21. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    #21 dahveedem, Apr 13, 2014
