Speed Bleeders | FerrariChat
Speed Bleeders
Discussion in '360/430' started by Ron8892, Sep 14, 2021.
  1. Ron8892
    Ron8892 Rookie
    Sep 24, 2018
    17
    Michigan
    Ron Hernesko
    Does anyone know what size the bleeder valves are for the brakes on the 360? I am looking at switching them out for speed bleeders and am unable to locate any details on them. Thank you!
  2. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I think the thread is 10 mm but I can't find my info to prove this
  3. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    found my notes
    The bleeder screws are 10 X 1
    So 10 mm X 1.0 mm thread
    Brembo bleeder screws M10X1 work well
    hessank and Qavion like this.
  4. Ron8892
    Ron8892 Rookie
    Sep 24, 2018
    17
    Michigan
    Ron Hernesko
    Awesome thank you!
  5. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    absolutely
  6. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Qavion likes this.
  7. RedNeck
    RedNeck F1 World Champ
    12,347
    The CSA
    Me
    Wow, why didn't I know about these?
    Need4Spd likes this.
  8. Qavion
    Qavion F1 World Champ
    14,343
    Ian Riddell
    Would you need 8 bleeder screws in total? There appears to be two bleed screws on each caliper (front and rear).
    TIA.
  9. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    have to admit that these are very clever
    will put my bride out of a job!!!
  10. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,119
    Josh @jtcarprojects
    That would be the best way
    Qavion likes this.
  11. tazandjan
    39,195
    Need some for the master cylinder, as well.
    Qavion likes this.
  12. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    and for the clutch bleed block
  13. WillskiGT
    WillskiGT Formula Junior
    Aug 12, 2017
    444
    Because, frankly, easy bleed screws suck. Leak around the threads, valves fail and leak/let in moisture, etc. Best to use standard bleed screws and make sure they are exercised once a year at minimum.
  14. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    that is of concern
    which ones have you used, WillskiGT, that have leaked?
  15. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,782
    I hadn't heard of 'easy bleed' screws before this thread and so I looked them up. I have the same opinion as you; maybe they would be OK in a cast iron caliper, but even then I wouldn't. In an alloy caliper - forget it.
  16. WillskiGT
    Aug 12, 2017
    444
    Couldn't tell you the brand name as they came already installed in an Audi RS4 I owned. The check valves had failed in both rear caliper bleed bolts and they did not get a good enough seal. So the system had a ton of moisture in it and would constantly weep brake fluid.
    Changed them for OEM and no issues.
  17. boostedt0y
    boostedt0y Formula Junior
    Dec 25, 2014
    806
    Bay Area, CA
    Have you considered purchasing a Motiv powerbleeder instead of the speed bleeders? It’s a fantastic tool for bleeding fluid.
  18. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I think I go with the analog approach and stay with the OEM bleeders
    Not like it's done every day and there is a need for efficiency!
  19. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    908
    S La
    Motive is by far the best brake bleeding tool and one person only. Glad that the Speed bleeders were dumped on because they are junk. If you need to use speed bleeders, you probably should not get near your brakes.
    Mario Andretti likes this.
  20. Mario Andretti
    Mario Andretti Formula 3
    1,779
    Boston
    I second this. I use Motive every year on my track car (M3) and every other car that I have or had. Takes longer to remove the wheels than to bleed the brakes. I also do a complete flush with this... totally worth it.
  21. boostedt0y
    Dec 25, 2014
    806
    Bay Area, CA
    yes I never had good success with speed bleeders as well. I used the motive power bleeder on my track Gt3 and it made bleeding brakes super fast and efficient.
  22. RedNeck
    12,347
    The CSA
    Me
    Well, sounds like the jury has reached a verdict. No speed bleeders for me.
  23. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    I can concur with other's experience with these.
    These were popular with the Ducati guys a few years ago, I got a set to help make bleeding easier at the track but they ended up making it harder because of the constant leaks.
    I also ended up putting the old bleeder valves back in and went with the traditional open/close way of bleeding.
    For the car, I use the Motive power bleeder
  24. WillskiGT
    Aug 12, 2017
    444
    Motive is the way to go. It's only like $50 for the power bleeder and works very well. The brake fluid for a single change (if you are using the good stuff like SRF, Endless 650, RBF660) is 2-3x that anyway.
  25. boostedt0y
    Dec 25, 2014
    806
    Bay Area, CA
    funny my experience with speedbleeders was from my track Ducatis lol
    timwu12 likes this.
