Buy
Speed Bleeders
Discussion in '360/430' started by Ron8892, Sep 14, 2021.
  1. HammerPants
    HammerPants Rookie
    Jan 1, 2020
    22
    Asheville, NC
    I have the Motive Power Bleeder but have never been able to get a good seal on the brake fluid reservoir in my 360. It seems that the rubber gasket inside the cap is too thick and prevents the threads from screwing down fully, which causes the cap to pop off or begin leaking air as the pressure builds. Is there a trick to this that you guys have figured out?
  3. boostedt0y
    boostedt0y Formula Junior
    251
    Bay Area, CA
    Carlo
    Take out the rubber gasket
  4. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    588
    Swamp
    There are different caps for different cars. Seems like I have three different caps and a few different rubber seaps? The reservoir cap must be tightened down real tight but I have never had a problem with the seal.
  5. boostedt0y
    251
    Bay Area, CA
    Carlo
    the motive I received only came with a single cap. Removing the rubber seal has worked in my experience for cars that had trouble getting a proper seal.
    Also, I was watching a video from normal super car guy or something along those lines and he was having issues bleeding his 430 or 360 as mentioned above using the motive. In the video I saw removing the rubber gasket solved the issue.
  6. kes7u
    kes7u Formula Junior
    Oct 18, 2017
    877
    Shorewood, MN
    Kevin
    Mine holds pressure just well enough! I do have to run back and forth a few times to check the fluid at the bleeder and add some more pressure to the Motive, though. I will try removing the rubber gasket. Will save me some calories....
    Kevin
    Sent from my SM-G960U1 using FerrariChat.com mobile app
