speed reduction gearbox | FerrariChat
Discussion in 'Canada' started by fabstar, Oct 13, 2005.
  1. fabstar
    fabstar Karting
    Feb 5, 2005
    67
    Sydney,Australia
    Fabio V
    All you mates out there.fabio from australia looking for a small gearbox(speed reduction gearbox)
    size appox 100mm by 100mm
    input on top,output on bottom
    ratio 118:1
    Can't find it down under but I heard I can find it in Canada or the States.
    If anyone knows where I can buy this or who I can talk to that knows anything about it.Could you please reply.
    All the Best.
    one words says it all: FERRARI
  2. Peter
    Peter F1 Veteran Owner
    Dec 21, 2000
    6,440
    B.C., Canada
    There are a chain of stores here in Canada called: "Princess Auto" which sells alot of surplus industrial & farm stuff (ie: crap), for good prices at least! I've often seen gearboxes there that can be used for whatever you'd want (but really not for automotive applications).
    Try them:
    http://www.princessauto.com/PAcountry.cfm?CTRY=CAN&INF=home
  3. fabstar
    fabstar Karting
    Feb 5, 2005
    67
    Sydney,Australia
    Fabio V
    thank peter I give it a go
  4. ClassicFerrari
    ClassicFerrari F1 World Champ Lifetime Rossa
    Jan 7, 2004
    16,798
    Toronto
    Vasco
    There is/was a specialty Transmission shop here in Toronto that was once the best there was. They were having some troubles so I need to see if they are still around. They would build custom transmissions for anything among other fabrication including choppers. I will get back to you if I see that they are around.
    TomB may know them....They are/were at the corner of Dixie and Queensway? APR? Somhthin like that. I was in there once, they had fabrication machines and lathes till the eye can see.
    Ciao
    Vasco
  5. gerritv
    gerritv Formula 3
    Jun 18, 2001
    1,400
    St Catharines
    Gerrit
  6. fabstar
    fabstar Karting
    Feb 5, 2005
    67
    Sydney,Australia
    Fabio V
    Thanks Mate. I will check out the web site
  7. ClassicFerrari
    Jan 7, 2004
    16,798
    Toronto
    Vasco
    Found it....
    http://www.api-racing.com/
    If they are still in biz, I do not know. But these guys were one of the best apparently.
    Hope this helps.
    Cheers,
    Vasco
