News
Speedline 18" wheels on Ebay
Discussion in '308/328' started by f355spider, Dec 15, 2007.
  1. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,268
    Hugh G. Rection
  3. barefoot
    barefoot Karting
    Apr 27, 2004
    62
    Will they fit a non ABS 328?
  4. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,135
    Austin, TX USA
    Greg
    Personally, I wouldn't go larger than 17" on a 308/328, but that's just me....
    Greg
  5. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,872
    CA and OR
    pit bull
    Aren't they a little wide? If I could make them work with just spacers or minor inner fender mod's I'd be interested.
    Have the QA1's and Eibach springs which I think facilitates slightly larger wheels.
    Thinking about ordering a set of Bogart RR10's . . . approximately 2K and they're lightweight.
    http://www.bogartracingwheels.com/bwheels3.htm
  6. vetroresina
    vetroresina Karting
    Dec 20, 2005
    170
    Holland & Germany
    Marcel
    These wheels look top of the heap.
    Especially the open star centered modular type.
    These are seriously my taste.
    In case you buy them, please keep me informed.
  8. luckydynes
    Jan 25, 2004
    3,872
    CA and OR
    pit bull
    Will do. .. can anyone confirm the size of rim you can run with QA1 setup?
    Going wider than 7's on the front reduce steering travel? . .. Have 16' repro's right now . . 7's on front and 8's on back from memory yes? No steering issues.
    Thanks,
    Sean
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    11,962
    The twilight zone
    The Butcher
    Without flares ot suspsension mount mods about 8-8.5" in front and 9-9.5 in the rear. I have 8.5 in front and 10.5 in the rear, but had to move the lower shock mounts in the rear.
    These wheels would be nice with GTO fenders
  10. BigTex
    Dec 6, 2002
    74,279
    Houston, Texas
    Bubba
    Auction says that size is TR fitment and that sounds right.
    Greg328 is correct that's about +4" over our early OEM, it'd make it look like 4WD!
  11. luckydynes
    Jan 25, 2004
    3,872
    CA and OR
    pit bull
    Thanks . . . not to hi jack . . . but like to see how you moved your shock mount . . . probably a thread already? Think I'd like that much rubber in the back and the additional in front.
    Do you get any rubbing on the fronts at full lock when parking? I know there's issues over bumps with heavy lock even with stock size tires . . .. peeled my fender lip one day. Really messed it up.
    Sean
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    11,962
    The twilight zone
    The Butcher
    18's actually lok pretty good....at least to me. You have to lower the car a big though to make the low profile tires look right in the wheel well.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    11,962
    The twilight zone
    The Butcher
    I think I posted them on the old f-chat, so they were lost in the crash. I'll see if I can dig them up when I get home.
  15. luckydynes
    Jan 25, 2004
    3,872
    CA and OR
    pit bull
    Thanks . . . I started another thread . .. check it out would ya?
    Thanks,
    Sean
  16. luckydynes
    Jan 25, 2004
    3,872
    CA and OR
    pit bull
    Probably have to make new lug bolts, unless the angle of the stock bolt is the same as a standard lug nut . .. anyone? If it is I'll be sure to give them the critical dim's so we can re-use the stock bolts . .. maybe I'll contact them with the stock bolt dim's and see if they can make them work if different.
    edit: vague on the "standard" lug nut because that's what they refer to it on their website
  17. BigTex
    Dec 6, 2002
    74,279
    Houston, Texas
    Bubba
    OEM Ferrari bolts are conical on the bottom of the hex, ala centering lug nuts, no idea if that's what they mean.....
  18. vetroresina
    vetroresina Karting
    Dec 20, 2005
    170
    Holland & Germany
    Marcel
    edit: vague on the "standard" lug nut because that's what they refer to it on their website[/QUOTE]
    AFAIK these bolts are treaded with a common Euro tread and the conical section is nothing unusual. This would bother me the least.
    Marcel
  19. luckydynes
    Jan 25, 2004
    3,872
    CA and OR
    pit bull
    Marcel[/QUOTE]
    In another thead 91TR had a link for a supplier of the bolts in different lengths ,etc. for like $4/pc
    Thanks all,
    Sean
