Speedline SL079 wheel | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by middel308, Apr 15, 2013.
  1. middel308
    middel308 Karting
    Apr 26, 2009
    78
    Papendrecht, NL
    Jaco
    #1 middel308, Apr 15, 2013
    Hi guys,
    about 10 years ago I bought a Ferrari wheel just for decoration that was supposed to be a Ferrari 308 GTB/S wheel. Now owning a 308 GTS and since my wheels we're of I tried to fit it on the car and it doesn't fit..
    So it's not a 308 wheel?! Which model would it belong to..?
    It's a 16" Speedline wheel 8J wide. Stamps on the back say SL 079 and a manufacturing date of 10/80. Could it be a 365/400/412 wheel?
  2. samsaprunoff
    samsaprunoff F1 Rookie
    4,418
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Jaco,
    This rim would not be for a 365, as the 365's had knock-off/ centre-lock/ splined rims like used on the Daytona, Boxer, etc.
    If it is a 16" then it should be for a later 308 QV?
    Cheers,
    Sam
  3. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,670
    Looks like a 308 rear wheel. When you say it doesnt fit, what do you mean exactly ? Note that the 308 uses different bolt lenghts front and back, and attempting to fit the wheel using the wrong bolts may give you the impression it doesnt fit.
    The common 16" concave 308 wheel will fit all 3xx series except the ABS equipped 328
    which need the "convex" wheel -(they look completely different anyway).
    M
  4. middel308
    middel308 Karting
    Apr 26, 2009
    78
    Papendrecht, NL
    Jaco
    The 308 I own is a 83 QV and it has the original 16" Speedline wheels (SL 053). It does look like a rear wheel but at some points they are different. The rear (inside) of the wheel is completely different and the bolts on the original 308 wheels are more deeper in the wheel.
    I tried to fit it on the rear but the wheel touches the brake caliper so it doesn't go flat on the brake disc.
    The wheels on the 400i in this post look a lot like it..
    http://www.ferrarichat.com/forum/140821288-post109.html
    But are those original for this car?
  5. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,670
    400's came with 15 x 7.5" wheels
    400i had metric (TRX) wheels
    412 had metric (TRX) or optional 16" wheels. But the 412 first came out in 1985/86, much later than the date code on your wheel, so I can't see how it would be a 412 wheel.
    A popular conversion is to use 308 16" wheels ( eg Superformance ) and fit these using a spacer to 400 /412's - thats what's probably in the photo
    The '87 Testarossa also used a 8 x 16" front wheel, but again, the date code is all wrong.
    M
  6. dstacy
    dstacy F1 World Champ
    11,997
    GMT -5 & GMT +1
    Dave
    Not all 400i's had metric wheels. Series one 400i's had 15" wheels
  7. rustytractor
    rustytractor Formula 3
    Mar 25, 2012
    1,078
    London
    Russell Schacter
    Touche.......
