Speedo on right screen 2018 488GTB | FerrariChat
Discussion in '458 Italia/488/F8' started by DMantooth, Jan 28, 2019.
  1. DMantooth
    DMantooth Karting
    Dec 24, 2018
    92
  2. SoCal to az
    SoCal to az F1 World Champ
    15,089
    Arizona
    Ill have to double check but I dont think you can. I thought only information, radio etc were on the right side. I may be totally mistaken as I havent paid attention to this.
  3. Macki
    Macki Rookie
    Oct 3, 2017
    34
    Germany
    Simon
    of course you can, just press and hold the volume knob of your soundsystem. you can turn it completely off this way, then the speedo wil appear.
    you can also select wether you want a digital or analog speedo displayed. you can do this in the setup screen
    pdxjim488, Caeruleus11, kandi and 2 others like this.
  4. SoCal to az
    15,089
    Arizona
    I stand corrected. Thanks for the clarification.
  5. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,906
    France
    Holding the central button on the right satellite (between "back" on the right and "main" on the right) should do the trick, you select to show digital or analog counter in the menu of the left TFT.
    The right screen is multi purpose though, and for instance the navigation is always on the right screen - so if you use the navi map you cannot have the speedo on the right (because the nav cannot go to the left).
    Fortunately my car seems to default to the speedometer, but I admit it is not intuitive at all.
    pdxjim488, ca_scud and DMantooth like this.
  6. wrs
    wrs F1 World Champ
    13,916
    Lakeway, Texas
    William
    What I have noticed about that setting is the phone doesn't connect if you put the speedometer over there.
  7. Johnnugget
    Johnnugget Karting
    Jan 19, 2018
    134
    John Nugget
    Left screen is for vehicle settings, right screen for infotainment.
    putting the speedo on the right will shut down the infotainment controls - therefore they added the digital speedo to the left screen (wasn't possible in the 458).
  8. Cigarzman
    Cigarzman F1 Veteran
    In any event , nice rig you got there bro. Congrats man and all the best, Kirk
    DMantooth likes this.
  9. wrs
    wrs F1 World Champ
    13,916
    Lakeway, Texas
    William
    Yeah, that is what I concluded but I like the bigger speedo on the right as it's easier to see and I like the gauges on the left. That's how I mostly drive and I just ignore the phone when someone calls.
  10. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,906
    France
    You can have the phone connected with the speedo on the right, you cannot configure it with the speedo on the right but after it's done it can work (works on my car anyway).
  11. wrs
    wrs F1 World Champ
    13,916
    Lakeway, Texas
    William
    How do you get the phone to connect if you have the speedo on the right?
  12. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,906
    France
    I will have to check, but IIRC once the bluetooth has been configured to connect the phone, it can connect automatically and work (i.e. receive calls, you need the right screen to place calls) with the speedo displayed.
  13. Zombies
    Zombies Karting
    Aug 19, 2017
    74
    I use it this way all the time.
    You press and hold Options View for a few seconds, and it comes up. I use my left screen for the temperature gauges to know when the car is warmed up.
    The Bluetooth is weird this way though — I often have to get out of Options View, go to media, my music starts, and then press Options view again. I asked the dealership about it and they said there was no problem, so it’s a minor annoyance but part of my routine while I’m backing out of my garage.
    I love the speedo on the right and the VDA info on the left.
    488mct and DMantooth like this.
  14. DMantooth
    DMantooth Karting
    Dec 24, 2018
    92
    What temp do you consider the car warmed up? New to this whole Ferrari things so any help is appreciated. The manual says not to let it warm up but that is under the environmental section. Thanks!
    Sent from my SM-G960U1 using FerrariChat.com mobile app
  15. Zombies
    Zombies Karting
    Aug 19, 2017
    74
    It maxxes out around 180-190. Much lower than my previous ICE cars, but I’ve been in Teslas for a while so I’m a bit out of the game. It’s about a 10 min drive to backroads for me, and by the time I’m 3/4ths of the way there I’m good to go. I just enjoy having the gauges up as I start to push it.
  16. DMantooth
    DMantooth Karting
    Dec 24, 2018
    92
    Great tip! If I push the volume button to engage the speedo on the right TFT, it turns off the radio. If you press the options button, as you suggested, I can still hear the radio and see the speedo. Thanks
  17. Caeruleus11
    Caeruleus11 F1 World Champ
    11,626
    Congratulations on your new ride!
