Speedo reads double in Gt4 with 328 engine fitted? | FerrariChat
Discussion in '308/328' started by Stimbow, Feb 12, 2022.
  1. Stimbow
    Stimbow Rookie
    Sep 3, 2020
    19
    Uk
    Hi,
    I’ve bought a 308 gt4 with a 328 engine and box fitted. The Speedo reads double the actual speed.
    Ie. phone gps reads 50mph and Speedo reads 100mph!
    Am I right in thinking it’s to do with the speed sensor on the gearbox as they’re listed differently between 308 & 328(Mondial)?
    Also the mileometre doesn’t work? Not sure if it’s connected to the Speedo in some way?
    Has anyone done this conversation? or come across this problem?
    many help would be much appreciated.
    justin
  2. BigTex
    79,379
    Houston, Texas
    Bubba
    It absolutely is, the odometer problem.
    There's "early" and "late" speedo sensors, first of all, so spend some time in the Part Numbers.
    But I have no idea if an early 308 can be somehow modified to accept the 328 sender signal, or vice versa.
    maybe a call to PaloAlto Speedometer would shed light??
  3. BigTex
    79,379
    Houston, Texas
    Bubba
    ..and Welcome!!
    That sounds like SOME example of a GT4!!!
    Post up some pics and the VIN info..
    It's hard to imagine a salvage yard where they said:
    "Hey man!! Get the engine out of that red/tan car, and bring it around to stuff in the Series 2 Sunroof GT4!!"
    Hard to imagine but obviously it happened!!
    dinogt4guy likes this.
  4. BigTex
    79,379
    Houston, Texas
    Bubba
    Saving you some recon, the speedo sensor creates a square sine wave, that is then translated in an IC chip board (now obsolete) in the Speedo, that makes the needle go around!!!
    Wheeee!
    And the odometer of course is the cumulative measure of these gearbox rotations.
    You can almost see Fred Flintstone feet under the car!!
    greg328 likes this.
  5. BigTex
    79,379
    Houston, Texas
    Bubba
    Thinking it thru further, the simplest fix might be an age appropriate 328 Speedometer.
    Palo Alto will know,
    TRutlands might be able to help too..
    Brian Harper likes this.
  6. Stimbow
    Stimbow Rookie
    Sep 3, 2020
    19
    Uk
    Thanks BigTex for your reply.
    Definitely a lot to think about.
    So, the early one sends out a different signal than the later ones. From what I can see the two types are physically different?
    So, is there an earlier type which is physically the same as the later type but sends out the early compatible signal? Or is there just the two earlier/later to choose from?
    Not sure how who the two people mentioned are?
  7. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    159
  8. ragtop1
    ragtop1 F1 Veteran
    5,240
    Ontario
    Larry Warren
  9. Stimbow
    Stimbow Rookie
    Sep 3, 2020
    19
    Uk
    Thanks for the links. I’ll send them a message.
    I haven’t owned the car long. Most of the work was carried out before my ownership. If anyone’s interested I can put photos and the info I know about the car on the forum. Not sure where though?
    It’s a work in progress running project.
  10. ragtop1
    ragtop1 F1 Veteran
    5,240
    Ontario
    Larry Warren
    Post them here. You have to subscribe though. $15 is cheap for a whole new level of information
  11. Mark C Harvey
    Mark C Harvey Formula Junior
    Jul 17, 2018
    286
    West Hartford, Connecticut
    Mark C Harvey
    Congrats, sounds like a fun car. Is it the white GT4 from a Los Angeles collection?
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,322
    Dumpster Fire #31
    SMG
    GT4 uses a worm gear assy, shaft etc to turn the speedo sensor. QV and later is a reluctor wheel with magnetic sensor. No interchange possible at the gearbox end.
  13. Stimbow
    Stimbow Rookie
    Sep 3, 2020
    19
    Uk
    No, it’s not white. My one is red, based in the Uk and is a ex-formula classic race car. Nothing fancy, except the 3.2 qv engine came from Marenello UK as a crate engine a few years back and has still only done 1000 miles!!
    Mark C Harvey likes this.
  14. Vonbarron
    Vonbarron Formula 3
    2,261
    Westside Mofo
    S B
    I remember your car when I still had instagram, was following it along. Very cool machine
  15. Steve Magnusson
    26,785
    Do a search on "speedometer" posted by Member "alhbln" -- there will be a lot of information about this issue for you in those threads. Adrian (alhbln) is truly the demonstrated expert on speedometer, odometer, speed sensor issues.
  16. BigTex
    79,379
    Houston, Texas
    Bubba
    alhbin has also reverse engineered the replacement IC boards within the gauge.
    Perhaps "knowing the target" he could build your gauge into the later style of signal interface.
    Good luck!!
  17. Stimbow
    Stimbow Rookie
    Sep 3, 2020
    19
    Uk
    That’s great thanks. I really appreciate all your help. I’ll do a speedometer and alhbin search. Hopefully I can get it fixed.
    Vonbarran, yes that’s me on Instagram.
    I started the page on Instagram to document the cars journey and to make friends with similar cars to mine.
    If anyone wants to follow its: ferrari_308_gt4_qv
  18. dinogt4guy
    dinogt4guy F1 Rookie
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
  19. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Ask Adrian if he can make you a simple circuit with a flip flop to halve the pulses. I may also need one when I switch to the single coil MSD programmable ignition.
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,322
    Dumpster Fire #31
    SMG
    Just add MSD 8920 for the tach signal.
    derekw likes this.
  21. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    which/whose if I may ask
  22. Stimbow
    Stimbow Rookie
    Sep 3, 2020
    19
    Uk
    Hi, I’m still trying to find out as much history on the car as possible. Any help of results, owners etc. would be much appreciated. What I do know I bought it from Atchill Thorpe who bought it of Ben or Alan Cosby.
  23. Stimbow
    Stimbow Rookie
    Sep 3, 2020
    19
    Uk
    I may end up going 355 throttle bodies and independent ECU so I can loose the EFi so won’t be going the MSD route.
  24. Stimbow
    Stimbow Rookie
    Sep 3, 2020
    19
    Uk
    I haven’t chased anything or looked up Adrian will do soon. The joys of having a you a family.
    Thanks for the advice, much appreciated. I’ll be on it soon.
  25. Stimbow
    Stimbow Rookie
    Sep 3, 2020
    19
    Uk
    I mentioned my Instagram post on the car. I’ll try and put a few photos up soon. Don’t expect too much.
