News
Speedo removal 308 GTSi
Discussion in 'Technical Q&A' started by samtheclip, Jun 2, 2004.
  1. samtheclip
    samtheclip Karting
    May 30, 2004
    176
    Buffalo, NY
    Sam Pasceri
    My odometer works fine but, the speedo is bouncing. It does keep the correct miles though. I would like to remove it and have it repaired. Can anyone tell me how to go about removing it?
    Thanks!
    81 308 GTSi
  2. tbakowsky
    tbakowsky F1 World Champ
    Professional Ferrari Technician Consultant
    Sep 18, 2002
    15,098
    The Cold North
    Tom
    To remove the speedo you must remove the entire gauge cluster. To do this you have to pull out the 4 round lights in each corner of the cluster. Behined them are philps screws, remove them. To make this easier I remove the streeting wheel, by removing the 3mm allen head screws. CAREFULLY remove the cluster as to not marr the leather with the corners of the cluster. Disconnect all the wiring and there you have it!!
  3. samtheclip
    samtheclip Karting
    May 30, 2004
    176
    Buffalo, NY
    Sam Pasceri
    Thank you for your reply!
  4. Darolls
    Darolls F1 Veteran
    6,799
    Sparky
    Be careful pulling out the 4 lights, as the plastic tabs that hold them in place can easily break.
  5. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,058
    Hugh G. Rection
    Uh, you might want to check the archives...but it may just be the electronic sender, not the speedo that is acting up. The sender is screwed into the transaxle in back.
