News
Speedo sensor dismantled
Discussion in '308/328' started by Portofino, Jun 2, 2020.
  1. Portofino
    Portofino Karting
    Sep 17, 2011
    228
    Yorkshire UK / Switzerland/ Cote d Azur
    Portofino
    #1 Portofino, Jun 2, 2020
    77 GT 4 with a early type 1 .
    Usual symptoms flickering needle , or nothing , intermittent, or works fine so you tend to leave it .
    22 mm metric bolt holds it vertically on the RHS of the gearbox near the fwd bank exhaust pipe .
    13 mm holds a wire clamp .
    In the winter I did just remove it and placed in the airing cupboard for a week .....improvement but gradually the time it does not work was lengthening to exceed the time it worked .
    Read a few threads on here about disassembly .
    New part is in excess of £200 .
    Basically you have to open a factory ( Veglia ) crimp .
    This was stubborn ....placed it carefully in a vice and with a tiny screw driver acting as a chisel and hammer , worked around the edge of the rim .
    As you can see the metal is brittle and maybe I was a little ham fisted ....but I managed to open it .
    The Hall effect wheel was submerged by in oil !
    Some oil was splattered on the components them selves.
    So I used brake cleaner spray to clean it all up .
    O ring is intact and there was oil either side of it ,
    I have smoothed down the plastic lid and when it’s finished drying in the sun I will resemble using a silicon sealant ..as well as obviously salvaging as much of the damaged crimp as possible .
    I will put a ring of silicon on the outside of the crimp where it’s meets the body .
    Unless anyone has any other suggestions to seal it up on reassembly ?
    There are little key ways on the lid + body = it only reassembles one way .
  3. Portofino
    Portofino Karting
    Sep 17, 2011
    228
    Portofino
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Re sealed it with a bead of exhaust under the o ring , a bead over it and re crimped the remains of the crimp .
    This set quickly.
    Then used a flexible oil / water resistant “ gutter sealant “ to make a seal and run off around the top .Taking care to seal the wire in port ( which seemed ok ) and particularly the lower lip of the crimp .
    I think ageing ....the o ring looses its elasticity, the heat cycles between the plastic top , metal case , rubber o ring = inevitably of it opening up = leaks oil or water splash in .
    Well @£200 a pop I have nothing to loose .Its not pretty buts it’s a problem waiting to happen .
    Ps - Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login I,ll do my cam cover gaskets soon as from under I can see oil seeping .The cam seals seem ok .
    absostone and Milkshaker0007 like this.
  4. Portofino
    Portofino Karting
    Sep 17, 2011
    228
    Portofino
  5. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    348
    Midlands,uk
    Paul
    nicely done, great fix, time for a congratulate beer i think
