Speedo Sensor Veglia 681005 full of oil | FerrariChat
Discussion in '308/328' started by sack, Apr 11, 2024.
  1. sack
    sack Rookie
    Nov 6, 2023
    26
    Germany
    Marc
    Hi,
    since the speedo and odo in my recently arrived 308 (GTS '78) didn't work I checked and fixed several things. Still no luck. So I finally found the sensor not working (too, the speedo itself was broken as well). I dismounted and opened it as described at dinoplex and found it was standing in oil. After cleaning it already seems to work using my scope. It looked quite worn and surely leaky from the upper side. But since it was nearly full of oil I wonder if the oil maybe also penetrates from the gearbox side? The gearbox mounting looks (reasonably) dry though.
    Marc
  2. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    Same thing happened to me on my 87’ 328.
    My sensor was faulty and when I removed it, a whole lot of oil came out.
    Most probably caused by a faulty shift shaft seal where engine oil is leaking into the transmission.
    Replaced the seas and alls well now.
    The sensor was faulty though and required replacing.
  3. Rifledriver
    37,089
    If the breathers are not working it will pressurize internally and push oil places it does not belong.
    maurice70 likes this.
  4. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    Where are the breathers and can they be checked easily enough?
  5. Rifledriver
    37,089
    It is an extensive system. Consult your shop manual. I do not teach auto repair 101.
  6. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,148
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I've had several friends experience speedometer sensor failure (including me).
    If you've disassembled the sensor, cleaned up the internals and (somehow) confirmed they are still working, you might consider reinstalling them but "potting" the assembly rather than just using factory o-ring style seals. Potting the electronics will stop oil from contacting them.
    Here is an example of potting epoxy:
    Amazon: MG Potting Epoxy
    I have replaced my sensor with a potted sensor, but used a prototype replacement board. Here is a link to the war story:
    Need failed Speed sensors
    MaranelloMark likes this.
  7. sack
    sack Rookie
    Nov 6, 2023
    26
    Germany
    Marc
    I have cleaned it up, renewed the wiring and reassembled it. I have not filled it with resin but sealed it with a new o-ring and silicon compound. Finally I put a heat shrink tube on top and bend the hose downwards, thus it should be 100% protected from the upper side. I did not touch the sealings from to lower side since these seemed fine on closer inspection. The oil is coming coming from the rear cylinder head and covers all the engine downwards which I have to check and fix. The speedo works fine for now.
  8. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    subnet67 likes this.
