speedo stuck | FerrariChat
speedo stuck
Discussion in '308/328' started by Ferraripilot, Sep 2, 2006.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,859
    Atlanta
    John!
    Hey everyone, I know this subject has been touched a bit but, my speedo is stuck at 70 mph on my '76. Is this the sending unit or the guage? The issue just started happening today....
    thanks- john
  2. LarryS
    LarryS Formula Junior
    Nov 14, 2003
    302
    Fremont, CA
    Larry S
    The problem is the speedo, not the sender.
    Sometimes the needle warps a little, then it drags on the background or glass, tapping on the glass usually returns it (unless there are bigger problems with the mechanism).
    Palo Alto Speedometer can repair it.
  3. Ferraripilot
    May 10, 2006
    17,859
    Atlanta
    John!
    I have been trying to tap the thing back into position, but it does not want to pop back. My odometer is still fully functional which leads me to believe that this is a minor issue. ANy further ideas anyone>?
  4. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
    Hi John,
    Try this for more info...
    http://www.ferrarichat.com/forum/showthread.php?t=101159&highlight=rjay
    If the link doesn't work, search for 308 "Speedo, Odo, Sender fix"
    I did this on a '78 308 and it may be similar to yours. The speedo section is separate from the odo section. Being stuck could be caused in several areas internally. They come apart pretty easily. The tough part is getting the bezel off.
    Good Luck,
    - Rjay
