speedo | FerrariChat
speedo
Discussion in '348/355' started by busted348, Nov 29, 2007.
  1. busted348
    busted348 Rookie
    Oct 16, 2007
    9
    speedo stopped working on my 348,anyone know where the sensor is located?
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,575
    The Brickyard
    The Bad Guy
    1) Remove the instrument pod and make sure that the connection on the back of the speedometer is clean, and plugged in correctly.
    2) The speedometer sending unit is located on the bottom left side of the transmission (looking at the car from the back).
  3. julian_blk348
    julian_blk348 Karting
    Nov 21, 2003
    112
    Austin TX
    Julian
    How easy is it to remove the instrument pod?
  4. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    There are two phillips head screws on the lower edge of the instrument housing. Remove the screws, lift up the housing, unplug the wiring connectors, and it's off. Two minute job, if you take your time.
  5. f355spider
    f355spider F1 World Champ
    17,938
    I put money on it, that it is the sender on the transaxle. Every Ferrari I have owned (3) has required replacement of this piece of junk made by Veglia! I have NEVER replaced a speedo sender on any other car I have owned, but Ferraris. Thankfully they are easy to swap and not terribly expensive (around $125 from Ricambi, depending on model). I have also replaced a Veglia oil temp sender (308, and had a Veglia clock repaired (308) and tach repaired (328). Veglia is living up to the "Italian made" stereotype... ;)
  6. Standig
    Standig Karting
    May 13, 2002
    152
    Spring Hill, Fl
    Stan DiGuiseppi
    Its the sensor
    Bending over the rear bumper its under car on left side of transmission
    I found the part chearper directly from Ferrari
    No special tools to install
