Speedometer accuracy | FerrariChat
Discussion in '308/328' started by godabitibi, Jun 15, 2023.
  1. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    My new to me 328 speedometer is way off on the speed indication.
    I can't remember if there is a driven gear that can be swaped to correct it.
    It is at least 10% off and maybe more.
  2. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    High or low?
  3. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    It read more than we actually go. We checked it again today and it can be up to 20kph faster like read 140 when doing 120.
  4. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    It should be pretty accurate, maybe the speedo pick up is bad, I would replace it. The speedo is electronic, and the pick up comes off the transmission I believe.
    G
  5. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    Mine is off by about 5%. It reads high. Always has, and I've owned the vehicle for 36 years.
    Ferraripilot likes this.
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,245
    CT
    John Kreskovsky
    Same for me with my 85 QV, owned since new. Reads about 5 MPH high. Always has.
  7. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,083
    FRANCE
    The one on my '89 GTB is accurate to the exact kilometer: if it says "90" it means exactly 90, not one more, not one less.
    (And I have a dozen speeding tickets that I know are right...)
    The one on my '89 GTS is lying by 5 km/h too much: if it says "90", then 85 it is.
    Rgds
  8. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    But 15 to 20 is a LOT MORE. I would like to fix it.
  9. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    Is the signal read in volt or frequency ?
    Can it be adjusted at the speedometer ?
    I had replaced the sensor on my 308 as it was working intermitent but it was a mechanical driven sensor.
    I haven't removed this one but from the pictures of the parts catalog it look like a magnetic type.
  10. JohnnyTS
    JohnnyTS Formula Junior
    Jun 3, 2012
    907
    Pretoria East, RSA
    my '89 shows 120kph when I drive 120kph on the GPS !
  11. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,265
    Worcester, England
    Phill J
  12. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    Yes that is what I understood looking at the parts schematic. So the speedometer itself is out of adjustment. Do they have some internal potensiometer to adjust them ?
    waymar likes this.
  13. afterburner
    afterburner F1 Rookie
    3,477
    Switzerland
    Urs STEMMLER
    The ones on the Mondial have a pot for adjustment, using the same sensor.
    waymar likes this.
  14. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    … you could always buy tires with a different circumference. :D
  15. godabitibi
    Jan 11, 2012
    6,329
    Claude Laforest
    Ok thanks that was my wish.
  16. ClydeM
    ClydeM F1 World Champ
    11,952
    Wayne, NJ
    Clyde E. McMurdy
    There are several threads here on updating the speedo/sensor.
    I thought mine always over reported the speed.
    I had to send it off to Atlantic Speedometer(if memory serves) for a new tub.
    They also calibrated it.
    now, 40 is the sweat spot.
    Under 40 it under reports the speed. A local sign shows me I'm doing 25 when the speedo says 20
    40 is dead-on
    over 40 and it over reports the speed. I can be doing 55 (per any of those highway speed signs) and the car shows 60 or 65
    and of course when I'm stopped, I'm still going over 10MPH.
