Speedometer calibration (88.5 US Testarossa) | FerrariChat
Discussion in 'Technical Q&A' started by Threeofnine, Jun 29, 2024.
  1. Threeofnine
    Threeofnine Formula Junior
    Dec 11, 2020
    385
    Birmingham, AL USA
    Jarrod Heath
    My Testarossa has 18” wheels and I assume that has thrown the speedometer off a bit. It appears to read slower than actual speed. When the speedometer reads 91 MPH, GPS speed shows 100 mph. When the speedometer reaches 100, GPS is reading 114. The faster you go, the worst the discrepancy.
    I know that neither the speedometer nor GPS speed are entirely accurate. However, judging by the fact I’m passing traffic like it’s standing still, I’d say the GPS is the most accurate. What needs to be done to calibrate the speedometer?
  2. Steve Magnusson
    26,542
    #2 Steve Magnusson, Jun 29, 2024
    What matters is the effective OD (rolling radius) of the tire, not the wheel diameter size. You must be running a huge tire as it's more typical for manufacturers to have their speedometers read a little high (so the actual speed is a little lower or, worst case, accurate) -- or the calibration was just never correct. What rear tire size are you using?
    This thread has some information from Adrian about how to calibrate a 308 speedometer that uses the same speedometer sensor as your TR:
    https://www.ferrarichat.com/forum/threads/1982-308-gtsi-speedometer-wrong.455815/#post-143325739
    but since you have your own calibration standard (GPS) you could just try tweaking the potentiometer on your speedometer until you get what you want.
    Threeofnine likes this.
  3. Threeofnine
    Dec 11, 2020
    385
    Birmingham, AL USA
    Jarrod Heath
    Thanks for the response. The current tire sizes: rear 295/35 zr18, front 235/40 zr18
  4. Steve Magnusson
    26,542
    That rear tire size is totally reasonable, and should cause less than a 1% increase in actual speed so your issue has to be on the electrical side of things. Good Hunting!
    RayJohns, f355spider and Threeofnine like this.
  5. Threeofnine
    Dec 11, 2020
    385
    Birmingham, AL USA
    Jarrod Heath
    Thanks Steve. I really appreciate the guidance!
  6. RayJohns
    RayJohns F1 Veteran
    7,819
    West Coast
    Ray
    I checked on line and the 1988 should have originally come with 255/50R16 in back
    P255/50R16 --> 255mm x .50 x 2 + 16" rims = 26.03" OD
    P295/35R18 --> 295mm x .35 x 2 + 18" rims = 26.13" OD
    The outside diameters are so close, I wouldn't think it would negatively affect the speedometer to this degree. Perhaps there is a failure in the electronics (as I think Steve was indicating above there).
    Ray
    f355spider likes this.
