Speedometer pulse sensor | FerrariChat
Discussion in '348/355' started by jm348ts, Mar 23, 2013.
  1. jm348ts
    jm348ts Karting
    Oct 22, 2009
    95
    New York
    John Moy
    I have been driving with the speedometer not working. Thanks to the brotherhood I received tips to replace the pulse sensor located near the transmission oil level dipstick. I recently located and purchased a new pulse sensor and have been waiting for warmer weather to change the fluids and replace the sensor. I just took it out for a short ride and was surprised that the speedometer and the odometer are working! THE OLD PULSE SENSOR IS DISCONNECTED! Any clues on how this can be?
  2. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Nope, you got me on that one, but I will mention that sometimes there are corrosion problems where the wiring harness plugs into the back of the speedo unit. you might want to pop the instrument pod off and check that area.
  3. jm348ts
    jm348ts Karting
    Oct 22, 2009
    95
    New York
    John Moy
    Thanks for the suggestion. I already did that before purchasing the pulse sensor.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    If it's working while disconnected you obviously unplugged the wrong thing.
  5. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    I need re replace the speedometer sensor on my 348. Does anyone know if I need to drain the transmission oil first before removing the sensor?
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,594
    San Carlos, CA
    Mitchell Le
    The only possible explanation. There can be no other reason.
  7. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I know you don't need to drain it on a 355 if that helps.
  8. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    Thanks, I think the mounting on the 355 is higher than on the 348.
  9. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    #9 mpodgor, Jul 10, 2013
    I had to replace my 355 speed sensor. Seems like a messed up design for a so called "sealed" sensor to fail so often. At least they are easy to replace and not too expensive. It must be like the sensor on my bicycle. A magnet is attatched to the wheel spoke and sensor on the fork. As the magnet flys by the sensor it induces a small DC current. Darn thing should last a lifetime unless it's physically damaged. Just my thoughts on this.
  10. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    Mine seemed to be going bad at the track a few weeks ago and then it just started working again for the last 200 miles with no issue... Should I change it or wait until it goes bad again?
    I know someone is thinking it's like the guy who was waiting for his "oil light" to get brighter before worrying about adding oil.
  11. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Anyone consider the fact that this sounds much like a connection problem rather than a sensor problem? Quite often it is......
