speedometer sending unit.... | FerrariChat
Discussion in '308/328' started by etip, Apr 10, 2009.
  1. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Does anyone know where to get a new one for a 1980 308gtsi?? I understand they're unobtainable....
    Mine died while the car was laid up for a year during it's rebuild.
    Thanks for advice.
    etip
  2. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
  3. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Thanks! I looked, but they don't seem to have one (that I can find, anyways)
    Does anyone referb these things??
  4. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,278
    Netherlands
    Steven
    use goggles ;)
    Ferrari 308 GTSi (1981) - GENERATORE D'IMPULSI
    Part No. 116987
    Superceded From Part No. 197181
    Supercedes To Part No. 393650106
    Will This Fit My Car? (Click To Find out)
    NEW
    To Order
    £69.40
    Approx €79
    oggles:
  5. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    5,761
    Indiana
    JIM
    #5 jimshadow, Apr 11, 2009
    GT Car parts
    Dennis McCann.
    I just replaced mine. I believe McCann shows yours on his website. thoughicouldbewrong...
    NOPE, just checked using PN# 116987 and here's what I found:
    116987 SPEEDOMETER SENDING UNIT, 308i/308QV/328/348/512BBi (MARELLI/VEGLIA # 680517) $175.75
    1 results
    Personally, I would call GT Car parts first with that Part Number. They typically have the best prices. FWIW.
    JIM
  6. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I thought you had a cable running your speedo?
  7. stephenofkanza
    stephenofkanza Formula Junior
    Mar 5, 2005
    542
    Kansas
    Stephen LeRoy Sherma
    Welcome to sender hell (sorry).
    1. I cleaned my connections ( removed the spades from the nylon and and cleaned them with contact cleaner - reassembled ) and the sender WORKED!
    2. If that does not work MAKE SURE you order the correct sender - most suppliers do not accept returns on electrical componets (which senders are).
    3. Is your sender mounted on the top or the botom of the transaxle?
    My parts book for my 81 showed it on the BOTTOM but mine was on the TOP part #106324/124146. The price is about double for the TOP - GT parts, T.Rutlands, Ricambi.
    Stephen
  8. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Great info. Thanks!
    I'll start with getting mine out and cleaning it well. I have some boat electrical contact cleaner I'll use.
    If that doesn't work, I'll call GT and Eurospares.
    Thanks again.
    etip
  9. stephenofkanza
    Mar 5, 2005
    542
    Kansas
    When you put the connectors back together use ( and I can't spell) dielectric grease. It is used to make good contact and prevent corrision (rust).
    Stephen
  10. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Will do! Thanks Stephen.
  11. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    *** + 1, use dielectric grease whenever you pull any electrical connector apart. I use contact cleaner first, make sure the contacts are clean and dry , then the dielectric grease to prevent future corrosion.
  12. jimshadow
    Feb 19, 2006
    5,761
    Indiana
    JIM
    I DO have a cable running to mine. :) Sorry about that confusion...!
    I had looked at all the different senders for the various 308 models. No real consistency with these.
    JIM
  13. stephenofkanza
    Mar 5, 2005
    542
    Kansas
    Just curious my 81 serial 37463 build date May 81 has the sender on the top part number old/new 106324/124146.
    Which do have Etip?
    Stephen
  14. theunissenguido
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    #14 theunissenguido, Apr 12, 2009
  15. stephenofkanza
    Mar 5, 2005
    542
    Kansas
    #15 stephenofkanza, Apr 12, 2009
  16. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,534
    Cerritos, CA.
    #16 miketuason, Apr 12, 2009
