430 - Spider cap(s) not closing | FerrariChat
430 Spider cap(s) not closing
Discussion in '360/430' started by 328gts1987, Apr 16, 2024.
  1. 328gts1987
    328gts1987 F1 World Champ Lifetime Rossa Owner
    Mar 11, 2007
    13,009
    Rotterdam Holland
    Fred
    This weekend went over to a F430 owner which had convertible issues.
    First the hood didn't close at all but after manually close the roof and then manually open it it started working again. However one part (the covers next to the roll over protection bar) is not closing...
    Windows go up automatic and no beeping sound/alarm to be heared.
    Also display on tach does not show any warnings.
    Any idea's how the caps close manually?
    Do the close by spindle of are they pushed upwards (hydrolics)?
  2. 328gts1987
    Mar 11, 2007
    13,009
    Rotterdam Holland
    Fred
  3. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,290
    Ian Riddell
    The flaps are electric motor driven. There is a common single motor with two cable drives.
    Experts?
  4. DutchFerrari
    DutchFerrari Formula Junior
    Apr 7, 2022
    778
    Bollenstreek - Netherlands
    Jeroen
    To add to @328gts1987 explanation as I went to help the same car:
    We found out that the hood that covers the roof when open (ima call it a deck lid for now), doesn't open all the way itself so it can open or close its roof, it needs to be held a little further and then it will open and close automatically. However we also found out, that the system doesn't seem to hold its pressure, as when we paused the opening/closing of the roof to check under it, the deck closed on my head, on my own F430 spider i can keep it all paused without it folding closed, no leaks to be found. I'm thinking an internal leak in the pump? and that this leaking inside the pump also is the reason for the deck not fully opening itself as it just give enough pressure in the system? is that possible for these pumps? any one what knows?
    Qavion likes this.
  5. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,781
    Look to be some other issues with that roof. The storage panel lid isn't sitting correctly, and there's a witness mark on the top of the B pillar seal, in fact it appears to have worn through.
  6. 328gts1987
    Mar 11, 2007
    13,009
    Rotterdam Holland
    Fred
    agree, however those marks were there from previous owner period. The roof worked fine (having scrapes/damages from before) untill next week when it the issues started not closing the flaps (as pic above).
    My geus is as Dutch Ferrari, the pump is losing pressure internally (as no leaks are found and fluid-level is not changing) so swap the pump is the way to go, I am thinking. Only problem: where is this pump located and what is the pump exactly?
  7. LorenzoR
    LorenzoR F1 Rookie Rossa Subscribed
    Sep 26, 2015
    3,173
    Sarasota Fl/Pittsburgh
    The pump is behind the passenger seat and behind the pillar
  8. LorenzoR
    Sep 26, 2015
    3,173
    I agree with mark here. The way the lid is sitting, it appears.The top is not folding correctly. I don't know what the driver side looks like. But by the looks of the passenger side the top is not folding correctly. It could possibly be bunched up which does not allow the lid to sit the way it should. I went through this problem. And Mark shows the problem in his long thread that he has going. Soon as I get out to the car I'll post pics of the the area I'm referring to
    DutchFerrari likes this.
  9. DutchFerrari
    Apr 7, 2022
    778
    Jeroen
    It depends on which pump we are talking, ive found multiple pumps, but one is labled as a ECU at the same time (and a whopping price tag of 21K)
    The one circled in purple im talking about. Parts number # 66376000 but this is labelled as a Electrohydraulic ECU, which i dont think will be the part that gives the issue.
    The on i think is the issue, is the one circled in red. Which to me seems to be the pump that pushes the roof lid up, so the roof can fold in or out of it. parts #66454200 (LH) & 66454300 (RH #8 on the diagram forgot to circle it)... to me it seems these are the issue, or atleast 1 of them, as the lid needs a very minor push for the roof to operate and move on its own once the lid is moved abit more.
  10. LorenzoR
    Sep 26, 2015
    3,173
    in the purple circle is the pump. The red circle is a cylinder not a pump
  11. LorenzoR
    Sep 26, 2015
    3,173
    Fyi this is what the top should look like when it's folded down. Sometimes the inner backing of the top will come loose causing that part shown in the pic to not fold correctly. First pic is driver side, second is passenger that was repaired. You can see excess glue on the inner side that's not visible when top is up
