Spider convertible top removal for clutch job ??? | FerrariChat
Discussion in '360/430' started by Schumi76, Oct 9, 2010.
  1. Schumi76
    Schumi76 Formula Junior
    Feb 15, 2006
    329
    NC
    Marco
    #1 Schumi76, Oct 9, 2010
    Does the convertible top mechanism on a 2003 360 Spider 6 speed has to come out to do a clutch job ??? On some later 360 models it can stay in but I don't remember which years anymore. Thanks !!!
  2. djantlive
    djantlive Formula 3
    Jun 30, 2005
    1,015
    needs removal for clutch job
  3. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    I do not think it does. So put me down as a No vote..
    I believe you can stop top in motion to get to the front screws (acccess through the bottom of the lower cover area) to get the square tube support out.
  4. Diablo
    Diablo Formula Junior
    Funny thing is that there are some early 99's that do need the top to be removed.
    They lack the access to the 8 front frame bolts.
    On the later cars, you can remove the oval rubber piece to access.
    The rest of the frame can be loosened by the rear bolts.
  5. RapidEM
    RapidEM Karting
    Dec 18, 2008
    131
    Los Angeles
    Edward
    Early 99 Spider?
  6. ferrarilou
    ferrarilou Formula Junior
    Apr 13, 2004
    513
    US
    Lou Menditto
    Diablo is correct - sort of. The early cars (2000) needed the top removed. My MY2001 does not because of the extra access holes that were added as model improvements.
    Lou
  7. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    As far as I understood... the first year of the 360 (1999) did not have a spider version... That started in model year 2000 as far as I knew..
  8. Skidkid
    Skidkid F1 Veteran
    9,539
    Campbell, CA
    John Zornes
    I believe it was 2000 in Europe and 2001 in US.
  9. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
