360 - Spider roof issues | FerrariChat
360 Spider roof issues
Discussion in '360/430' started by rizzo308, Sep 4, 2024.
  1. rizzo308
    rizzo308 F1 Rookie
    2,780
    Perth, Australia
    riggio
    My friends spider is having roof issues the dealer is saying both the main hinges are worn and need to be replaced. Has anyone had the same issues and is there anyone out there that can repair the hinges. TIA
  2. GogglesPisano
    GogglesPisano F1 Rookie
    3,205
    East Bay, California
    Joe
    What are the symptoms and are there any pictures of the wear? Worm hole or something else? I’d probably do a quick eBay search for used replacement parts if they’re truly worn.
  3. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,853
    Memphis, TN
    It's highly unlikely that the hinges are the problem. They are quite stout and will likely outlast the car by 100 years.
    I'd get a second opinion on that. If the main hinges are out of spec, it's likely the entire capote is ruined. In that case, leave the top down and get a car cover. There's very little that can be done to repair a completely worn out capote other than jacking up the gas cap and driving a new car under it.
  4. Michael_1982
    Michael_1982 Karting
    Mar 15, 2020
    95
    Perth
    Michael
  5. 6ated
    6ated Rookie
    Sep 4, 2024
    16
    Salt Lake City, UT
    Bradyn L.
    If you can send some pictures I'd be happy to help come up with a solution with you. These tops are old and have many common points that fail but hinges would be a first for me. I run a shop in Utah (Rev9 Group) and if you're local bring it by and we can take a look, otherwise let's see what we can figure out, if you'd like.
  6. priericky128
    priericky128 Formula Junior
    680
    St. Louis MO
    Rick
    I had some issues that I thought were hinges but ended up being shim/alignment issues.
    I have some right side hinges if you need them. I don’t remember exact part numbers since I am not with the car at the moment but I will be back next week.
  7. LorenzoR
    LorenzoR F1 Rookie
    Its highly unlikely hinges are bad, especially both sides. What are the symptoms hes having
